Hello, I am extremely confused with the model of Tom-Tom I have. It was a gift. I have had many issues since the day I turned it on, looping, corrupt file errors, messages can't save files. Can not link USB ect. The information found on label as below, Tom-tom XL N14644 Canada 310 (4EG0.001.00) I have read through posts and see there are others also confused. Please can you id what version I should reference on the Tom-tom sight. The software is corrupt on this unit from the factory and it limps along with error messages as noted. I am at the point thinking of just putting it in the garbage. This unit has been a huge disappointment Rgds George
SOURCE: can you delete information on tom tom
Do you mean on a ONE XL, XLS, or XL 330S? Do you mean simple deletion of history, or actual files on the device?
For deleting history, you can go into the preferences menu and Reset the Device back to Factory Settings. Say that you're sure 2x and its all cleared.
For more advanced deletion of files...
If you have the USB cord, connect it to your computer. Download and install the TomTom HOME software and register your device. From there, you can access the contents of your device and download new data or delete old files.
What are you trying to delete?
SOURCE: My tom tom keeps looping on the start up menu
I to had this same problem. I just about pulled my hair out. The way I fixed mine was to use Tom Tom Home to operate the Tom Tom. It was able to get past the loop and finish the initial set up. I then unhooked it from the computer and it was working by itself.
SOURCE: tomtom ONE (4NOO.001) 023289 N14644 FCC ID SALONE IC5767A-ONE
my tomtom worked well the other day. have not use it for 5 days. try to turn it on today, does not work. try recharging for 2 hrs still the same, does not turn on. please help
SOURCE: how to open tom tom n14644
Came apart eventually, click action!
Surface mount USB was a little tricky to remove, got there in the end and resoldered new part on.
If a Usb cable is inserted awkwardly the internal pins can be easily bent and damaged, rendering your device useless, good job i have experience with removing Usb's.
