SOURCE: Electronic Display
This is a common problem with Jenn-Air and Maytag that I have found. There is no way to brighten the display and usually requires the replacement of the Electronic Oven Control (EOC) board. I think this may have something to do with the placement of the board and possibly being damaged by heat from the oven over a period of time. Do you do a lot of baking? Do you use the self-clean mode for your oven a lot? These seem to be contributors to these boards failing like they do. I know of one person who has replaced the EOC 6 times on the same stove. I don't know if this is the advice you were looking for, but I hope it helps you.
SOURCE: Jenn- Air SCE30600B
It's a bad capacitor on the clock/display board. The solution was posted elsewhere in FixYa. I had the same problem and was told I should replace the clock/display board, which would solve the problem, but costs about $150 plus labor. If you can desolder/solder small components on an electronic circuit board, you can fix this yourself. Mine was capacitor C3, originally a 68uF 35V component. I replaced it with a 68uF 63V as the closest one I could find at Jameco.com which was less than a $1. Lo and behold, my clock/display is back to normal! Saved a lot of money to fix it myself and I know it will happen again over time, so I know exactly what to do next time.
Further inspection found that the ribbon got damaged during the re-instalation of the clock board. A new front control board had to be ordered and installed.
Go to, fixitnow.com for a cheap fix on these displays. It worked on my jenn air.
SOURCE: Jenn-Air free standing range: displays
Hello there
This a common problem with these
F9
Door lock
safety circuit on power relay board sensed
Replace power
relay boardok I would contsact the nearest appliance parts repair center to see if this can be replaced and how much it would cost and mayby you can do it yourself it would save you a lot of money ok?
hope this is very helpful for you
Best regards Michael
