20 Most Recent Jenn-Air SVE47100 Slide-In Electric Kitchen Range Questions & Answers
think getting in an electrician to check the unit out as it is a safety issue
Jenn-Air... | Answered on Dec 19, 2017
on the front panel does it have a button that says CLOCK if so press that then with + button see if setting changes if so when it gets to the correct time stop and press clock again .
Jenn-Air... | Answered on Oct 25, 2017
Thirteen years old? Replace it.
Jenn-Air... | Answered on Apr 10, 2017
First, try turning off the power to the unit for a minute then repower it up. sometimes this will allow unit to reset. Second, try resetting the unit to clean again waiting one minute then cancelling the clean cycle and see if it will unlock. Third, make a J shaped "hook" out of heavy coat hanger or use an allen wrench. You will need pliers to hold it. Slide it in from right to left at the top of door where the latch is between door and main oven. When you get to the latch (in the middle) you will have to pull hard to the left in an attempt to move the latch hook. A little movement of the entire door to the right will also be needed in getting it to open. Main question is . . . what caused this? If all of the lights are out, it may be the thermal fuse on the unit. Sometimes these blow out when running a self-clean cycle.
Jenn-Air... | Answered on Aug 24, 2014
The problem lies with the circuit boards. However, I'm not sure it's with the control/relay board or the display board. More likely the former one, but again, I'm not sure.
Jenn-Air... | Answered on Jun 14, 2014
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
346 questions posted
Top Jenn-Air Kitchen Ranges Experts
Thomas F. Schneider
Paul Carew
Ismael Rodriguez...
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Jenn-Air Kitchen Ranges
Most Popular Question
jenn air mod sve47100 oven not
  • Kitchen Ranges
