If you run into the error "This device cannot start. Code 10 (often followed by a driver identifier, for example "This device cannot start. Code 10 in audio driver"), here is what it means.
The Windows error "This device cannot start. Code 10 or "This device cannot start. (Code 10)" is a hardware error that most commonly means that you have a bad, missing, or incompatible device driver. So, for example, "This device cannot start. Code 10 in audio driver" means that you have a bad or missing or incompatible driver for your sound card.
The technical explanation for this message, according to Microsoft, is this:
"If the device has a FailReasonString value in its hardware key, that string appears as the error message. The driver or enumerator puts this registry string value there. If there is no FailReasonString in the hardware key, you receive the following error message:
What does that mean in plain English? It means that if the device which is throwing the error has added its own custom error text to your Windows system when the device was installed, then when the device encounters an error, you will see the custom error message specific to that device. But if it doesn't have its own custom error message, then Windows uses its own generic error message for devices, which is "This device cannot start. (Code 10)"
Microsoft recommends that when this happens, you click "Update Driver" to update the drivers for the device. You can also start the Windows troubleshooting wizard by going to the general properties tab of the device, and clicking on "Troubleshoot".
Before doing this, be sure that you have the correct and most up-to-date versions of the driver(s) for that device. You can also try uninstalling and reinstalling the device, using the disk which came with it.
Finally, you can go to the website of the device's manufacturer, and check their downloads or support section for current, up-to-date drivers.
Go to Toshiba support site look for Toshiba Satellite A135 drivers, download the one for your windows 32 or 64 bit install, restart and off you go. Regards, Mike
SOURCE: speaker showing No Audio Output device is installed
Try to uninstalled the audio driver.then restart the machine and again install the audio driver.hope this will work for you.
Thanks
SOURCE: Unknown device on high definition audio bus
go to toshiba download drivers to dir. burn a CD with all the drivers on it that way you have them all and can install them anytime you have problems there two l300 listing this is the one I think you need so go to this link.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2221250&rpn=PSLB8U&modelFilter=L300-ST3502&selCategory=3&selFamily=1073768663&selModel=2221250%7CPSLB8U
Good luck.
SOURCE: drivers for satellite L310
i need drivers for my satellite L310, PLS HELP ME CNF7051 ETHERNET CONTROLLER MASS STORAGE CONTROLLER MODEM DEVICE ON HIGH DEFINITION AUDIO BUS PCI DEVICE SM BUS CONTROLLER VIDEO CONTOLLER VIDEO CONTROLLER(VGA) UNKNOWN DEVICE
SOURCE: TOSHIBA LAPTOP SATELLITE L310 drivers
http://www.elitezoom.com/toshiba-satellite-l310-windows-xp-driver.html
link
and this link also ,,,
http://www.getpcmemory.com/drivers/download-toshiba-satellite-l310-notebook-windows-xp-drivers/
HI
A Code 10 error is generated when Device Manager can't start the hardware
device, a situation usually caused by outdated or corrupted driver A device may
also receive a Code 10error if a driver generates an error that Device Manager
doesn't understand. In other words, a Code 10 error can sometimes be a very
generic message indicating some kind of unspecified driver or hardware problem.
Uninstalling and then reinstalling the drivers for the device is a likely
solution to a Code 10 error. If reinstalling driver is not working than try to
rollback the driver or restore the system on previous date..
regards
sandy fixya
