SOURCE: I would like to set the tax on my Victor 1240-2
How to set the rate:
You can download the User Guide for Victor 1240-2 Calculator from here:
http://office.manualsonline.com/regman/exit/ct?url=aHR0cDovL3d3dy52aWN0b3J0ZWNoLmNvbS9hZG1pbi9pbWFnZXMvcHJvZHVjdHMvMTI0MC0yLnBkZg,,&target=productDoc&idDeviceType=2702&idMfg=19347&idProduct=2734212
SOURCE: How do I set the time on my calculator
To set the time on this calculator, you must press and hold the time key until the display is flashing 0. (Hint: you will want the date displaying when you are going to set the time as when you press the time key to hold it, it will switch over to the time.) Once the display is flashing you type in the time using the keypad. If you were going to set the time for 9:30, you plug in 930 and push the time key again. If you need to set it for a time in the PM you would have to use the 24 hour scale; for example 1:30 PM would be 1330. To set the date, you press and hold the time key with the date displaying until the display begins flashing. Again you would use the numbers on the keypad to enter the date and press the time key again to set it. For 1/20/2011 you would type in 12011.
SOURCE: have a victor 1230-3 calculator
1. Set the [GT OFF/GT ON/ TAX SET] switch to "TAX SET" position to select set mode for the tax rate.
2. Press "5"
2. Press "5"
