20 Most Recent
Victor 1230-2 Calculator Questions & Answers
Load new reel of paper
Assuming that you know where the paper gets feed in, I usually use this trick to start a new roll of paper.
First, tear off the end of the new roll so that there isn't any glue stuck on the paper.
Then, fold the tip of the paper like an arrow. > (Fold one side to the middle and the other side to the middle so both sides meet in the middle.
Then, place the paper into the slot where the paper feeds in.. (Usually goes under the printer assembly) and then hit the PAPER FEED button at the same time. If the paper is in the correct slot, the paper should start feeding the paper all the way through.
Hope this helps.
Have a good day.
M =)
Victor 1260-2 will power on, give a very short hum/buzz then go quiet and not work.
It sounds like there may be an issue with the motor that drives the paper feed mechanism. The hum/buzz that you hear when you turn it on could be the motor trying to start but failing to do so. The tightness of the paper feed could also be related to the motor issue.
The green "E" on the screen likely indicates an error. Without more specific information about the error code, it's difficult to determine the exact issue. However, it's possible that the error code is related to the motor or paper feed issue.
If you're comfortable doing so, you may want to try opening up the machine to see if there are any obvious issues with the motor or paper feed mechanism, such as a loose or broken part. If you're not comfortable doing this or if you're unable to identify the problem, it may be best to take it to a professional for repair.
My Victor 1560-6 adding machine is still printing light even after changing the ribbon
Here are some potential issues that could be causing the problem:
- Worn or damaged print hammer: The print hammer is the part of the machine that strikes the ribbon to transfer ink onto the paper. Over time, the print hammer can become worn or damaged, which can cause it to strike the ribbon with less force, resulting in light printing. If you suspect this is the problem, you will need to replace the print hammer.
- Dirty or misaligned print hammer: Even if the print hammer is not worn or damaged, it can become dirty or misaligned over time, which can affect its ability to transfer ink onto the paper. Clean the print hammer with a soft cloth and make sure it is properly aligned with the ribbon.
- Worn or damaged ribbon guide: The ribbon guide is the part of the machine that helps guide the ribbon over the print mechanism. If it is worn or damaged, it can cause the ribbon to slip, resulting in light printing. You may need to replace the ribbon guide.
- Misaligned or dirty print mechanism: The entire print mechanism may need to be cleaned or realigned to ensure that it is making proper contact with the ribbon and paper. Consult the user manual or seek professional assistance to properly realign or clean the print mechanism.
- Electronic malfunction: If the issue is not related to any physical components, there may be an electronic malfunction that is causing the problem. Seek professional assistance to diagnose and repair any potential electronic issues.
How to replace the ink cartridge on a victor 1208-2
https://www.google.com/search?q=How+to+replace+the+ink+cartridge+on+a+victor+1208-2&oq=How+to+replace+the+ink+cartridge+on+a+victor+1208-2&aqs=chrome..69i57.1446j0j15&sourceid=chrome&ie=UTF-8#kpvalbx=_UgODYaXHBpGHwbkP48yAqAI71
