Amazon.com, Inc.Amazon.com: LAPTOP CHARGER FOR ACER ASPIRE 3600 3680 SERIES 3650 ...When I was looking for a charger cable for my laptop, i was not sure whether I ... it was really good and worked, it heats up a little bit but for now its working ...
Aug 18, 2015 - When Your Acer Aspire 5738Z Laptop Adapter is Not WorkingA ...Quicker Charging of Laptop Battery with an Acer Aspire 3600 AC Adapter ...
Acer Aspire 5517 shows BLUE light when fully charged.
Start it and check battery indicator (tray item) will probably say
plugged in fully charged (with adapter plugged in)
OK, it sounds like the acer aspire one 751 has a bad battery that will need to be replaced. It is not taking a charge, so it is not detected even though it is connected to the laptop. The 'plugged in' message shows that the charger is connected and detected by the computer, but the battery is 'not charging' due to the bad cells.
check the output of the charger and see if it is charging if so the conector might be bad does the plug wiggle when it is plugged in? it should feel very solid
I had the same problem with my Aspire One in the past. When I would plug in my Aspire One it would not charge, but would emit a foul smell. I had to send mine to Acer. The problem was caused by a short in the charging terminal on the mother board. They replaced the mother board and since then my Aspire One has been running as good as ever.
