Philips 42PF9630A 42 in. Plasma Television Logo
Posted on Jun 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Philips Plasma tv 42pf5321d/37 with sound but no picture
The other night while watching the tv there was a very load pop and the picture and sound went out and the LED on the front started blinking red. I unplugged the tv waited 10 minutes and then plugged it in again. The TV worked I had sound and a picture again, but after 15 minutes there was another very load pop again and the picture and sound were gove again and LED was blinking red. I unplugged it again and then plugged it back in the next morning and now I have sound, but no picture and the LED is green. Any suggestions would be greatly appreciated
Anonymous
Level 2:
Sniper:
  • Expert 63 Answers
  • Posted on Aug 03, 2010
Anonymous
Expert
Level 2:
Sniper:
Answers
63
Questions
Helped
36739
Points
202
Thats the great sound of Exploding capacitors on either the power supply board. or another one in there. Now the set is in fault protection. It tried to warn you with the RED blinking LED that there was something amiss by shutting itself down. When you unplugged you reset the error and allowed it to do it again.
Best Regards and Smper Fi
3 Related Answers
Anonymous
  • 210 Answers
  • Posted on Oct 01, 2009
SOURCE: plasma tv in protect mode
One of the PCB's inside has an incorrect voltage/short or dry joint, all TV now days have a diagnostic startup mode which checks all the boards, one of yours threw up a problem so the TV put itself into Protect Mode so that it doesn't do anymore damage.
Get it checked out by an engineer.
Thanks
phil_frye
Philip Frye
  • 295 Answers
  • Posted on Nov 19, 2009
SOURCE: My 42PF5321D/37 will not turn on, just flashes a
Most likely a power supply problem. If it's covered under the warranty take it in right away and have them fix it. If not a good Philip's service shop can fix it. They may have a flat fee repair charge?
Blessings,
A/V Guy
Azrael SRL
  • 11800 Answers
  • Posted on May 13, 2011
SOURCE: philips plasma 42pf5321d/37
4 blinks is an error on the I2C bus 3 - the one that holds VIPER (the protection system), Stand-by Processor, and NVM. Since this is triggered by the processor when the NVM can't contact the Viper or it's not powered (the 12 volts line to it is missing) the digital board was operational and it was changed for nothing.
Most likely the defect is in the power source and you will have to replace it. To help you use this service manual for a very similar unit
http://www.scribd.com/doc/6528782/Philips-42pf7320
I have a Philips 42pf5321d/37 that won't turn on.
send me a email [email protected] and I can assist you with troubleshooting it to determine whats happening with the set.
1helpful
We were watching tv last night and it the picture just turned off. the machine was on but no picture. i turned off the tv and tried again this am. no picture.
You either need this part (http://cgi.ebay.com/Philips-50PFP5332D-37-LJ92-01401-Buffer-Board-/150501144120?pt=LH_DefaultDomain_0&hash=item230a913638) or this one depending on your dead screen issue (http://cgi.ebay.com/Philips-50PFP5332D-37-LJ41-04216A-X-SUS-XSUS-Board-/170550290208?pt=LH_DefaultDomain_0&hash=item27b596e720)
PHILLIPS PLASMA TV MODEL #42PF9431D/37 Heard
Hi, Usually any "Pops" are an Electrolytic Capacitor "blowing up" quite literally, or "Gassing" as it is called. This happens due to some sort of power problem. Capacitors hate AC Voltage and Current, and Heat and Over Voltage. All of which, I have no doubt it was exposed to before it went "Pop" This is only a symptom of a far greater problem, to come, no doubt, soon, the rest of the set will fail too. Please DO NOT USE. this set any more, you risk fire or explosion or both. If you MUST use it at least unplug at bed time. Theses days home repair except for the most rudimentary problem is not feasible, setting aside the safety aspect. In my professional opinion, I would recommend, that you get a "Quote" for repair from a Philips Authorised Service Agent This is very important, that you contact a Philips head office and ask for a referral. This way at least you can make a decision to repair or replace.
My 42PF5321D/37 will not turn on, just flashes a red standby light. I have a Philips Plasma model number 42PF5321D/37.
Blessings,
A/V Guy
Plasma tv in protect mode
Thanks
1helpful
Tv get wet and not turnig on
when electronics get wet they tend to short out.
so some part of the electroncs is damaged.
you will have to take it in for repairs
3helpful
No Picture just 4 red blinking lights
Look For TWO 10 Volt 33000 mfd. Caps That Appear To Be Swollen,They Are Next To Each Other At The Bottom Of The Power Supply Board, Change Them To 16 Volt Versions.
No picture on tv. model 42pf5321d/37. red light flashing on lower right. flashes 4xx see Morgan ref. 719nt
Purchased new Pansonic TV,, old one [2 years] was not projection tv. In for repair for kids.
Yamaha RV1103 receiver
YOU SHOULD BE ABLE TO RUN SOME PHONO LEADS TO THE AMP FROM THE CONECTORS ON THE BACK OF TV THE SOUND CONNECTORS ARE USUALLY WHITE AND RED JUST CONNECT THE CORRESPONDING LEADS TO THE SAME COLOURED CONNECTORS ON THE AMP
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
