20 Most Recent
Philips FTR-9964 Tuner/Receiver for Plasma Questions & Answers
Philips FTR 9964 Receiver Problem
The problem is in your cable connection on the back of your monitor or Box. I had the same problem and solved it by reattaching the VGA cable that was loose.
No tv channels with Philips 42FD9935/17
If you are using a Cable Box, then select the Cable Box option in the TV. If you have connected the Antenna directly to the TV, then select the Antenna option in the TV under Menu options. Try performing the Auto program.......If using a Cable Box, then no need to perform the Auto program. If the issue persists, try resetting the TV to the factory settings and check if it helps.
With all this Philips plasma
yes, Sony has a very good quality. Sony has been in market over the years and they are known to produce quality products.
Also, electronics in generally are not to be trusted. It can develop fault at any given point in time. This might be as a result of irregular power supply or factory error.
But Sony is good electronic product. One also has to be careful, so that the fake one won't be bought.
I agree with you that Sony has a very good quality and that true.
Take care.
Cannot swtich on the tv
I think you mean ' switch ' and ' only the red light ' ( power ) comes on.
It could be an internal trip on your tv set that needs looking at by a tv engineer ( normally parts required ) or if you have a tv with a ' factory settings button ' on it ( normally on the side or top if it's a flat screen tv ) press and hold for 10 seconds then the intial ' tv setup ' will appear on the screen ; after that, just follow the guide.
Hope this helps.
Menu
I download new software from internet and insert to TV and it works.
