Computers & Internet Logo
A
Anonymous Posted on Jan 31, 2018
Wireless capability turned on
I got the wireless turned on, but it will not join the network. It just spins and then says something about my IP being incorrect. I've rebooted my router (which works for other computers in the house fine) and the computer and it still will not allow me to connect to the router. Help please
Brett Duxbury
Level 3:
  • Toshiba Master 4,352 Answers
  • Posted on Jan 31, 2018
Brett Duxbury
Toshiba Master
Level 3:
Answers
4352
Questions
0
Helped
1120438
Points
13423
You just got wireless turned on ?
Does this mean you just added a wireless router to your existing wired network ?
You may need to turn off the DCHP server in the wireless Router and give it a unique ip address eg if wired router is 192.168.0.1 then make wireless router 192.168.0.2 with gateway ip set as 192.168.0.1 then make wired dhcp router not lease out 192.168.0.1 - 192.168.0.20 make subnet mask the same also for each router.
5 Related Answers
sriramoju
EKASYS IT SERVICES
  • 215 Answers
  • Posted on Mar 24, 2008
SOURCE: trying to connect to the internet wirelessly
is it detecting in the device manger if it detects in the device manager it show in the network connections . i think there is a switch for wireless enable or disable on the laptop
Anonymous
  • 50 Answers
  • Posted on May 21, 2008
SOURCE: Unidentified network
Your office network is probably hidden you will need to change the settings on the router. Talk to your Net Admin about it.
hashchathy
harsha gayan
  • 246 Answers
  • Posted on Jul 29, 2008
SOURCE: Computer will not connect to wireless router
Check the wireless network card
try to reinstall the driver
Anonymous
  • 340 Answers
  • Posted on Nov 23, 2008
SOURCE: di-524 dlink; wireless laptop connects but no internet or network
Your wireless card is dead, replace.
Anonymous
  • 12 Answers
  • Posted on Feb 18, 2009
SOURCE: Home Network Problem with Netgear MR814 and Netgear FS105
Is your ReplayTV and Xbox configured to use DHCP? If not, you may need to configure static IP addresses for each of them.
Wireless capability turned On but still not connecting
Maybe the maximum Number of devices are connected to the router
Check router settings
2helpful
Installing OKI c3400n in Windows 7 32 bit
The c3400n does not have its own wireless capability. It must be connected to a wireless print server or to some wired network that has a wireless access point (WAP) connected to it. A third option is to use a home-networking wireless router.
Individual PCs must have wireless capability also, or they can't print over wireless.
Somewhere along the line the printer must get a local network IP address, i.e. 192.168.0.102. PCs usually use Dynamic Host Configuration Protocol (DHCP) to get an IP address.
But printers are usually manually set to a 'static' IP, because static IPs don't change over time.
Usually there is a security device called a 'firewall' to protect the wired network from unwanted wireless traffic.
So, you first require some form of wireless access.
The people who require wireless printing capability must have their computers configured to make an association to the WAP. Usually requires a passkey or password, depending on the wireless security method.
A port on the firewall must be forwarded to the port used by whichever network-printing protocol is being used to communicate with the printer. There are several possible protocols.
The printer must be set to an IP address unique within the private subnet, i.e. 192.168.0.0/16, used by the local network.
PC-based network-connected devices use IP (Internet Protocol) addressing, i.e. xyz.zxy.yzx.xzy
The printer must be connected to a network switch that is in some way accessible to the WAP. Residential/SOHO (Small Office Home Office) setups use a combination switch/router device, called simply: a router.
Most of the above is done automatically, but there are some set-up tasks that require user intervention. Electronic devices know how to configure everything, after they are given proper parameters.
All you need to do is check the above items. If the printer is found by MS Windows 'searching for network printers', the hard part is done. Then you just tell Windows to use the network printer.
How do i connect my laptop to printer over a wireless network
First you want to make sure your printer has wireless capability. If yes, you want to make sure wireless is turned on. Log into your wireless router, and go DHCP section to find out what IP that assigned to printer. Once you know the IP, you can change the port of printer to that IP via control panel and printers and faxes. Good luck and let me know if need additional help.
What is a ssid code for printer setup
The SSID is the name given to a wireless network when a network is created. You can choose to broadcast or not broadcast the SSID of the network. If you hidden the SSID, then your wireless network will not be "visible" to other computers looking to join the wireless network, meaning that computers will only be able to join your network if they know the SSID beforehand.The SSID would be found on the router. This is for a printer that has wireless printing capabilities.On your computer click on the wireless network indicator in the status bar and you can see the SSID of the router the system is currently connected to.
1helpful
I need to either block certain ip or mac addresses or only allow a select few. how can i do this.
Well, when it comes to ip addresses, you must either turn off dhcp (which automatically gives out ip addresses to devices joining the network) and assign static ip addresses to each individual device on the network, or simply decrease the number of ip addresses your router's dhcp gives out by narrowing the dhcp range. Blocking ip addresses is an ineffective way of preventing access to the network. MAC Address filtering, on the other hand, is much more secure. Usually this is locating under Wireless - MAC Filter in the router's configuration page. When you get to the menu, you usually have the option of making an allow or deny list. If you are having problems with unknown devices, I would go with allow only option, and enter each of your device's MAC addresses. The one main problem is that you will have to do this every time a new device is added to the network, but it makes the network much more secure.
Wireless capability. Device manager says that wireless card is enabled and functioning properly, but it can not find my network. No swith to turn on/off the wireless capability.
First make sure that wireless LED status is on on router.
Then if it is ok then uninstall wireless driver from device manager then reinstall it.
if you haven't driver disk then download from below link.
click here
Then if still same issue then you need to access your router.
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on wireless settings enable wireless
Also change channel type to 3 or 6 or 11 then save settings and restart router.
Let me know if you need further assistance.
Thanks for using FixYa.
1helpful
(2) xbox 360's in same home; 1 wireless adapter, other ethernet
you need to assign a static ip address to each inside your router they are more than likely using the same ip address
I cant play games online
You do not need a DMZ for ps3. jsut setup a SSID if wireless. Encrypt it (for your own saftly) and PS3 has wireless capablity. Just join the network with the SSID and WEP key and the PS3 will get an IP address. Also no port mapping is needed. Leave all port to auto open due to DHCP is going to get your PS3 a new ip every time you turn it on.
2answers
Where to find password to join wireless network?
Hope this helps
Chris (ziraffa)
Got a belkin 802.11g wireless adaptor have followed instructions to install it but every time i turn the computer on im having to repair the connection before it will connect,it usually just comes up with...
The issue here is the IP address that it is using. Each time you "repair" the connection it is asking for a new IP address from the router. So there is a few problems that might be existing, you may need to increase the TTL time for IP address leases so that you assigned IP doesn't reset in a few hours. Or you could static the IP address in a part of your subnet so that you dont have to recieve new IP address from your network (downside to this is you have to change this if you leave your network to try and join another)
http://www.hotcomm.com/FAQ/FAQ_staticIPXP.asp
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
