20 Most Recent Toshiba QOSMIO F15-AV201 Notebook Questions & Answers
2answers
Boot problem
Have you tried putting in the windows disk that you have,
turn ur computer on
put windows disk in right away
your computer will boot off the disk
try repairing your windows installation,
DO NOT REFORMAT OR REINSTALL WINDOWS
hah i dont want you makin that mistake.
just repair your windows follow the directions on screen
Anything else im here to help. just ask!
7/12/2015 7:56:48 PM • Toshiba QOSMIO... • Answered on Jul 12, 2015
What processer in BIOS opction
Intel Pentium M 745 / 1.8 GHzhttp://www.retrevo.com/support/Toshiba-F15-AV201-Laptops-manual/id/614ag008/t/2/
9/8/2012 1:37:36 PM • Toshiba QOSMIO... • Answered on Sep 08, 2012
My qosmio f15 av201 no
Have you tried downloading the most recent driver from the Toshiba support site? The site can be found here: http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp Select your laptop's make and model, and look for the category "Driver" and "Sound". There should be a link to download the ADI WDM Audio Driver. Install that driver on your system and reboot.
3/21/2011 11:34:21 PM • Toshiba QOSMIO... • Answered on Mar 21, 2011
2answers
Qosmio F15-AV201 video
It's possible.
1/3/2011 9:12:15 PM • Toshiba QOSMIO... • Answered on Jan 03, 2011
2answers
I forget the bios paswword
There is a solution for your problem,
you have to remove *********** board battery cell from your laptop & than start your laptop once.
after that you shutdown your laptop & than you fix your battery again in your laptop's motherboard.
after that it will not ask you for any password.
Thanks
12/30/2010 2:13:57 PM • Toshiba QOSMIO... • Answered on Dec 30, 2010
Toshiba QOSMIO F15-AV201 PC Notebook that keeps on
Hi
Thank you for your query
Please can you try the following
Remove battery
Remove wall charger
Press and hold the power button down on the laptop fro 30 seconds
Plug in wall charger and power up the laptop
After approx 5 minutes slot in the battery and see if the issue occurs again
If it does then from the description it would seem the laptop is overheating, so plase can you ensure there is plenty of ventalltion around the laptop and if it still continues you will need to book laptop into a reputable PC shop to swa out the heatsink
Regards
shauqat
6/9/2010 8:00:03 PM • Toshiba QOSMIO... • Answered on Jun 09, 2010
3answers
Laptop screen and external screen have lost color
In my opinion if you have black and white screen internal and external screen while booting and while you are into windows desktop you have a faulty graphic card. Common fault on toshiba laptops.
Actualy the reason for their sales drops dramaticaly in the past few years ;)
5/22/2010 6:32:06 AM • Toshiba QOSMIO... • Answered on May 22, 2010
Scree Black and white
Please update your version of Windows if you are a Windows user. Some of the video drivers might have been outdated.
Also, this could be a sign of a hardware malfunction which requires repair. Try check the driver update first if it solves the problem.
5/8/2010 12:59:06 AM • Toshiba QOSMIO... • Answered on May 08, 2010
Toshiba Qosmio f15 - AV2
This is a common problem with laptops that haven't been thoughly cleaned in a while.
The first thing I do with these when I get them in the shop is to strip them down and clean the fins and the heatsink. Next I make sure the fan is working properly and replace it with an OEM unit.
Note: I havent seen an aftermarket fan match the quality of OEM for Laptops yet.
Finally I finish with some real quality heatsink compound and put it all back together.
With proper cooling we can now see whether or not we have some real problems.
Your hard drive could be toast due to the heat and it could be a compounded problem. However I have seen some perk up and run just fine after the cooling fan has been fixed.
4/14/2010 4:02:10 AM • Toshiba QOSMIO... • Answered on Apr 14, 2010
When i turn it on i get a black screen.i can hear
it booting properly & you hear the windows welcome sound. the disply dual it cant be viewable u can view litel bit is it then your FL got faulty and next is your lapi mother board not genrate 15v supply for F.L 90% your F.L faulty contact your location so i tell you local repair and kindly rate me
3/5/2010 10:43:14 AM • Toshiba QOSMIO... • Answered on Mar 05, 2010
My laptop wont turn on
When you boot up the Toshiba and it appears to boot up and the hard disk LED light flashes but you get a black screen then the problem is a back-light fault. This is caused by a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions :-
http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
3/1/2010 7:48:47 AM • Toshiba QOSMIO... • Answered on Mar 01, 2010
My Toshiba laptop won't let me sign on. When I
For User type in Administrator
Leave the Password empty
Provided no Administrator password has been set, this will provide a backdoor entry method.
2/6/2010 5:44:15 AM • Toshiba QOSMIO... • Answered on Feb 06, 2010
3answers
Media center unable to open messenger
The problem can not and will not be solved by a reinstall of the operating system or a reinstall of messenger. The issue comes from a security update from Microsoft. Go to this link to a blog written by a member of the microsoft Media Center Security Team, it has a couple of easy solutions to the problem. Click on the Registry fix downloads for whatever option you want to use. The fix, in a nutshell, is to either ban the security update from media center OR to stop messenger from being used in media center. Personally, I have no need for messenger let alone using it in media center. Good luck!
2/2/2010 4:45:41 PM • Toshiba QOSMIO... • Answered on Feb 02, 2010
2answers
Horisontal line on my screen
Horizontal Lines Indicate Your Display Panels Circuit Board Has A Short...You will Need To Replace The Screen
Ebay Sells Them For $85
1/16/2010 7:04:11 AM • Toshiba QOSMIO... • Answered on Jan 16, 2010
I have a toshba laptop. it came with a 160gb hard
Could you please clarify what the problem is? Are you trying to resize the primary partition to be 250 GB instead of 160 GB or what?
12/9/2009 1:22:15 PM • Toshiba QOSMIO... • Answered on Dec 09, 2009
How do I remove the invertor from a Qosmio F20?
The easy option is to Disassemble, i recommend you give it
  to a technician.
11/16/2009 11:06:38 PM • Toshiba QOSMIO... • Answered on Nov 16, 2009
My computer is windows vista, and it wont read discs.
go to this link and click fix it, should sort the problem
http://support.microsoft.com/default.aspx?scid=kb;en-us;314060
let me know if you need further help
11/16/2009 1:50:39 PM • Toshiba QOSMIO... • Answered on Nov 16, 2009
Toshiba QOSMIO F15-AV201 Notebook Logo
56 questions posted
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Qosmio Toshiba
  • Qosmio Toshiba
Most Popular Question
laptop screen external screen lost color
  • Computers & Internet
