Encoder ribbon
SOURCE: Lost installation disk for hp psc 2175 all-in-one
You can donwload the software for your printer from this link, just select the operating sysrem that your computer is using http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=90809&
SOURCE: PSC 2175 wont work with print server
Please make sure that the printer is working okay if directlysd connected to the MAC computer. You may try this as well. hope this helps
Description
LPR (line printer remote) is a platform independent printing protocol that is associate with TCP/IP. It works by using LPR client software that communicates to a server running LPR services.
In terms of PSU, LPR printing will become the basis for all network printing while Novell print queues are phased out. Therefore, all Macintosh, Windows, and Unix computers will be configured to print through LPR.
Requirements
· The name of LPR print queue. This can be found by searching the LPR printer database.
· LaserWriter print drivers version 8.5.1 or newer
· The Macintosh must have a working TCP/IP networking configuration. (If the Mac can browse the web then it's working.)
· a server running LPR services or a printer that supports LPR printing. Most HP LaserJet printers support LPR. However, only the following LaserWriters support LPR printing:
- LaserWriter 8500
- LaserWriter 16/600 PS
- LaserWriter 12/640 PS
- Color LaserWriter 12/600 PS
- Color LaserWriter 12/660 PS Procedure
1.Open up the Applications folder from the OS X menu.
2.Open up the Utilities folder
3.Now open up the Print Center
4.If you have no printers installed you will see the following screen. Click on Add.
5.On the following screen, select LPR printing.
6.Now enter printhost.oit.pdx.edu for the LPR Printer's address.
7.Uncheck Use Default Queue on Server option and enter the queue name of the printer.
8.Select the printer model.
9.The completed settings should be similar to the following:
(LPR Printer’s address is the ip of our PRINTSERVER)
10.Click on Add
11.Your printer has successfully been installed. Test the printer by printing something to it.
SOURCE: HP psc 2175 All in one died
Insert Printer Driver Disk And Uninstall The Printer Driver completely.Dont Remove It From Control Panel. You May Use Uninstaller Software.Here's The Link http://wugnet.com/shareware/spow.asp?ID=638.Installthis and remove printer driver. Delete temp and prefetch files as wellif you wish. Disconnect Ur printer from the computer and turn it off and then disconnect the power cable. Press n hold the POWER BUTTON on the printer for 30 seconds so that static is released. Disconnect all the cables from the back of the computer and then Press n hold the POWER BUTTON on the Computer for 30 seconds. Restart Your system and hook up the printer and visit the following website
DOWNLOAD AND INSTALL the latest driver software and firmware.
WINDOWS XP
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&lang=en&product=90809#
WINDOWS VISTA
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&dlc=en&cc=us&lang=en&product=90809
ANY OTHER OPERATING SYSTEM
FOR ANY OTHER OPERATING SYSTEM CHOOSE OPERATING SYSTEM AND DOWNLOAD AND INSTALL the latest driver software and firmware.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=90809&lc=en&cc=us&dlc=en&lang=en&cc=us&submit=Go%20%C2%BB
Restart Your System.
Issue Would Be Resolved..
Plz Rate The Solution Accordingly....
SOURCE: HP PSC 2175 Printer reverts to "default printer" on PC re-boot
click on start ---settings----printer and faxes now from here u can make a default printer just right click on the icon of that print which u want to use and set it as a default print. or if u just want to revert back the current one just uncheck the option by right clicking on the icon
SOURCE: HP psc 2175 all-in-one printer shows error:Right
Forgive me for asking this, but roughly speaking about 80 to 95% of problems involving ink or toner are resolved by the following:
Are you using a factory new ink cartridge supplied by the manufacturer of the printer?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
Don
