D-Link DU-562M Modem Logo
Posted on Jun 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have d-link 560e modem and i want at command to disable line hangup inorder to open other application after the connection is up
Anonymous
Level 2:
Scholar:
  • Expert 58 Answers
  • Posted on Jun 21, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
58
Questions
Helped
43339
Points
146
If the software that you are using with the modem does not have the ability to set the modem to autoanswer you will need to configure the modem manually. You will have to use Hyperterminal to enter the command into the modem's memory.
(if you do not have Hyperterminal installed please add it by going to Control Panel > Add/Remove Programs > Windows Setup > Communications > Details...)
Have the modem connected to your computer and ensure that it is working fine. Go to:
Start > Programs > Accessories > [Communications] > Hyperterminal .... Hyperterm.exe > name the connection "modem" > Connect Using... Select COM3 or COM4 (on whichever port the modem was assigned to) > Bits per second 9600 > OK.
After that try typing ATZ command and press ENTER (you may not see what you are typing). The response from the modem should be OK.
Apply the following command:
ATS0=3
Now write the new settings into the modem's memory by typing the following command and pressing Enter:
AT&W
The response should be "OK"
The modem will now be set to auto-answer after 3 rings.
What is the unlcok code for a huawai valiant
The unlock code for every individual mobile phone is unique and based upon the IMEI number of the device. You can visit ClassicUnlocking.com submit the required details and get the accurate unlock code at affordable cost. Good luck.
..............UNLOCKING INSTRUCTIONS..............
f your Huawei Device is a mobile phone:
1.Switch on your Huawei Phone using another networks SIM card.
2.Your phone should ask for an unlock code(NCK Code).
3. Enter the unlock code we sent you.
If your Huawei Device is an USB modem, please follow these instructions:
If your modem software asked for an unlock code when you tried using another network's SIM card, directly enter the unlock code we sent you when prompted by the software.
Otherwise try one of the following
Method 1:
This method requires your PC to have a software called Hyperterminal which can be found on the Start Menu in Windows XP, 2003 and other older versions of Windows:
Start - > Programs -> Accessories - > Communications - > Hyperterminal
1.Remove all other modems, printers and other devices connected to your PC other than your monitor, keypad and mouse.
2.Start your pc, connect your USB modem and open Hyperterminal.
3.Enter any name and select any icon and click OK to continue.
4.Set Connect using to your modem port, Huawei Mobile Connect - 3G Modem or the right COM port.
5.In the properties window that opens, without changing any values, click OK to continue.
6.Type the following command(replace the word UnlockCode with the unlock code we sent you):
AT^CARDLOCK=UnlockCode
and press enter.
7.Your modem should now be unlocked. Close Hyperterminal, disconnect your modem and connect it again.
Method 2:
Use this method if Method 1 does not work or if you are not able to follow method 1.
If your PC does not have Hyperterminal or if your using Windows Vista or Windows 7 you can use the following method.
1.Download our Modem Communicator Application. This application has been scanned by Mcafee and contains no virus. For your safety, please scan the application again after you download it.
2.Switch off your PC, remove all other modems, printers and other devices connected to your PC except your monitor, keypad and mouse.
3.Start your pc, connect your USB modem and open the application you downloaded(mc.exe).
4.Click on the Check for Ports button and wait for the response.
5.Click on the Check for Modems button and wait for a response.
6.Click on the Send AT Command button and make sure you get the response "OK".
7.In the text-box next to the Send User Command button, type the following command(replace the word UnlockCode with the unlock code we sent you):
8.Click on the Send User Command button.
9.Your modem should now be unlocked. Close the application(Modem Communicator), disconnect your modem and connect it again.
1helpful
2answers
PLEASE help unlock my device E5331s-2 IMEI::860667017553111
Hi. You can unlock your Huawei E5331S-2 safer and easier using unlock code. You can get the unlock code for a Huawei E5331S-2 from SimpleUnlocking.com at affordable cost.
If your Huawei Device is a mobile phone:
Method 1:
and press enter.
Method 2:
1helpful
Unlock huawei E353Tu-6 mobem
HUAWEI E353 TU-6 and Huawei E353 are same modem...You can Unlock it using the Unlock Code...Visit the site Prounlocking.com/huawei-modem-unlocking-service/rs8wp10/ get the Unlocking service for your HUAWEI modem and unlock it from service provider lock.Follow the instructions below and unlock it step by step...
Method 1:
and press enter.
Method 2:
6.Click on the Send AT Command button and make sure you get the response"OK".
I need the sim unlock pin code so i can switch over to Tmobile without getting a new phone.
Hi, You can get the unlock code for a Huawei U8652 Fusion from www.unlocking4u.com/huawei-fusion-u8652/rs6wp9/ at affordable cost.
Here are the steps for unlocking a Huawei U8652 Fusion,
Method 1:
and press enter.
Method 2:
There is an error in connect...........
If the error in connecting to the internet or to a LAN is prevalent with all network adapters, reset the TCP/IP Protocol stack byrunning the following command from the command prompt window:
1. Go to start menu and click on run.
2.Type in cmd.exe and press enter.
3.In the command prompt window,type in the command:
netsh int ip reset C:\connlogreset.log
The command will reset the TCP/IP protocol stack to it's defaults, and the reset data will be logged in the text document connlogreset.log.
If the above fails, disable any protocols that are not needed in the connection, e.g. SLIP(Serial Line Internet Protocol for Linux) as it's only used to connect to Linux servers in a LAN.
If using a broadband modem, disable NDIS driver wrapper from the GSM broadband client software provided with the modem, and update the software if possible.
How to connect DFM-560E to system or hp laptop
Check their site
http://www.dlink.com.au/tech/faq/modems/dfm560e.htm
Best to connect via lan cable, not usb.
2answers
Disable SIP AL
connect to the modem through telnet and type
application unbind SIP 5060 saveall
I want the driver for huawei fwt wireless modem
I'm giving you two links to download the drivers for Huawei fwt wireless mode
1- http://www.openpages.info/huawei.html and
2- https://answers.launchpad.net/ubuntu/+source/wvdial/+question/43266
You will probably need to edit the wvdial.conf file a little so that you are using the right connection parameters for your internet service.
If those URL's did not help, please follow this procedure:
Step 1: Open Terminal from "Applications->Accessories->
Terminal"
Step 2: Run the following commands (copy-paste each line below to the Terminal then hit <enter> after each line)
ifconfig
sudo lshw -C network
lspci -nn
lsusb
uname -a
dmesg | grep USB
Step 3: Post results (cut/paste terminal output from each command) here
Step 4: Provide us with the full model and make of Huawei modem. What is the exact model number? Does it connect to the PC using a serial-to-USB converter?
Internet Connectivity Problem
Try This,
Go to the command line and while connected to your modem type the following:
(Wait for each command to finish)
c:> ipconfig /release
c:> ipconfig /renew
c:> ipconfig /flushdns
c:> ipconfig /registerdns
Then attempt to browse one of the sites you were having trouble with.
If that does not fix the problem, then you will need to disable Norton Internet Security temporarily to see if that is causing your problems.
I'll check back to see how you made out.
Let me know how you made out.
Zexxal
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
