Whirlpool Cabrio WTW6600SBK Logo
Randy Olinger Posted on Apr 26, 2014
What is code oL - Whirlpool Cabrio WTW6600SBK
Lorenzo Lynn
Level 1:
New Friend:
  • Contributor 32 Answers
  • Posted on May 02, 2014
Lorenzo Lynn
Contributor
Level 1:
New Friend:
Answers
32
Questions
0
Helped
10101
Points
45
Ol is rarely actually over loaded. Check the tub by pulling up on it. You should get a slight movement .The tub floats .if if doesn't the shaft and tub will need to be cleaned with sand paper. Also check for obstruction under the tub. Turn the tub by hand it should turn freely. Good luck.
My GE top load washer model 110.27062603 will not run through a full cycle. Sometimes it washes, but 17 minutes showing, jumps to 2 minutes, then shuts off with 'OL' error code.
OL = Overloaded.
Is the Washer overloaded? If OL (overloaded) appears in display, the load too large. If an overload is detected, the washer will drain any water and detergent in the washer. Remove several items and add HE detergent.Feb 24, 2020
OL - Error Code - Top Load Washer - Product Help - Maytag
Maytag https://producthelp.maytag.com > ... > OL
The washer has ol on it at the end - Maytag Bravos quiet ...
iFixit https://www.ifixit.com > Answers > View > The+washe...
Oct 6, 2014 Ā· 2 answers
First, OL stands for "Overload", so in other words, the washer thinks the tub is too hard to move because it's overloaded and the motor is ...
OL code all the time even with very small and light ...
Sep 28, 2016
Why washer stops and gives code "ol" - iFixit
Nov 30, 2016
at the end it says OL - Maytag Bravos quiet series 300 ...
1 answer
Dec 29, 2022
OL code showing . - Kenmore 110 Series Washing ...
Sep 19, 2017
More results from www.ifixit.com
When machine goes into final spin cycle it gives me a OL code
OL means the washer is overloaded or there is excessive drive load. Go to the link for a full explanation of the OL code and its repair. What might be causing the OL error code on my Whirlpool Cabrio washer...
Ol code cabrio
"oL" error code, even when unloaded - Fixitnow.com
fixitnow.com/.../whirlpoolkenmore-cabrio-and-maytag-bravo-washers-th...
Sep 18, 2010 - The "oL" error code in the Cabrio and Bravo washers means the ... is almost always caused by using non-HE detergent in this washer- see this ...
Fuel system default code ol
Have the cylinder one misfire repaired and other codes will likely disappear.
2answers
OL error code
Hi jbrundage1. I believe you have a UL error code on the washer. It means that the sensors in the washer are sensing the unit is unbalanced. When the washer is empty, set it to a spin or rinse and spin setting. Run the washer through the cycle empty, as it will help to remove any excess water in the tub. Also, make sure the washer is level, as it is balanced on springs, and that could be throwing the sensors off. I hope these suggestions prove helpful. Sincerely, Melanie, Maytag Social Media Representative.
Our Neptune Washer won't start up. It shows a Code (ol). What does this mean? We;ve tried unplugging & and Re-loading it. Still OL code.
From the FAV6800A/FAV9800A Service Manual page 14 that error code = oL Machine Paused-Load Wedging
Google this "16022808 Revision 0 December 2003" to find the Service Manual if you are going to DIY the fix.
Kenmore washer OASIS errror code OL
OL error means the Motor Controller has sensed an Overload.
The oL code means the motor control board is struggling to power the motor up. If it recurs after removing some clothes - usually this means a new motor control.... or worse - a new bearing.
If it were a problem with the tub floating up, the unit would spin instead of nutate.
Bearing failure in this machine is very common.
I suspect the drive shaft and bearing are the problem. The bearing and shaft are part of the outer tub.
The new outer tub with bearing W10128830 cost approximately $197 dollars.
If you can get access to the shaft it may be an Emory cloth will help smooth things down so that you no longer get the OL code.
This is an ambitious do-it-yourself project... as most appliance repairmen don't understand how this machine operates.
http://media.fotki.com/1_p,srrtbrrfbdbqgkkxgtqsskgwtqkq,vi/bqkfstqqfxrqqbkwgqdxbwsqrwrtq/1/1303472/5961857/image828956817962821589img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Screen says oL. Kenmore oasis elite he 110.2708,2709
OL, usually means Over Loaded. It is an error code thrown up by the on board computer.. generally when TOO much wet weight is in the bowl.
1helpful
OL code. I have removed most of the items, but it
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
