Hello The assainged key for 'hash" is "SHIFT - 3" If it showas any other symbol than this, the inside membrane of the keyboard is faulty. You should contact the deler or Acer service center to make it right. OK. Here is it. I'm going to print a hash symbol here by holding down the Shift Key and the press the Digit key (3) ########## #############################################
Assuming you are in UK Open Control Panel Open Regional and Language Options In Regional Options ensure English United Kingdom is selected in both options In Languages click details and select English United Kingdom and remove US Keyboard
Hold down the ALT(ernate) GR(aphic) key -- to the right of the SPACE BAR on your keyboard.
Press the '2' key.
Release the '2' key.
Release the ALT GR key.
Does an '@' display?
Check that you are using the "American English" keyboard mapping.
Control Panel -> Regional options.
Hi, If the Keyboard was mixedup in msn only then there is no issue might be the Fn combination with the num lock or any other caused that. If keyboard charectors are printed wrong in DOS also then there is the issue with K/b so check it in DOS. You can check your keyboard by typing osk in run command and on screen k/b will be opened check if that is working fine then issue with the hardware and if this is also behaving like same then software issue.
