Hi, Sometines you can stretch the seal. T4ry and put a rolled up piece of paper towel and stick it behind the seal in the area that is not touching. If the seal is not touching in the corners, You might be able to twist the door back in shape. If the seal is open at the bottom, pull the top corner of the door toward you while holding the bottom corner against the refrigerator..
If neither of these ideas work, you will need to replace the seal.
Please let me know if I can assist you further.
Vic
Lift the door and then close the door ,try this
