Time I receive from TVGuide is 4 minute slow. How DO I Manually set the CM7000 time?
Hi Joe,
I found a link where in you can download a manual of CM7000. On the manual page 11 you will see there how to set up time manually. Hope it helps. https://www.google.com.ph/webhp?tab=ww&ei=sGdRU-n5L4ekyASqrIHoAQ&ved=0CBIQ1S4#q=CM7000+tv+guide ( please click "
CM7000 User Manual.pdf - Support - Channel Master"
Setting Time
1 In the Clock priority mode, press and hold
TITLE/ for at least 2 seconds while the time is
displayed.
The time indication will blink.
2 Turn the Rotary encoder (CDE-9846 only) or
press 4 and 3 (CDE-9842 only) to adjust the
hours while the time indication is blinking.
3 When the hour has been adjusted, press the
Rotary encoder (CDE-9846 only) or press MODE
(CDE-9842 only).
4 Turn the Rotary encoder (CDE-9846 only) or
minutes while the time indication is blinking.
The time is automatically set 5 seconds after the minute
adjustment. The time can also be manually set by
pressing the Rotary encoder (CDE-9846 only) or press
MODE (CDE-9842 only).
• To synchronize the clock to another clock/watch or radio time
announcement, press and hold the Rotary encoder (CDE-9846
only) or press and hold MODE (CDE-9842 only) for at least 2
seconds after setting the "hour." Minutes will reset to 00. If the
display shows over "30" minutes when you do this, the time will
advance one hour.
