Unless the tv has an integrated DVD player you will need a stand-alone DVD or Blu-ray player.
The player will need to be connected to the tv set by a scart lead, by a HDMI lead or by another type of connection.
I suggest reading the instruction leaflets for both the tv and the player.
Sometimes the tv will switch automatically to the input from the DVD player and sometimes a special channel will need to be selected.
Hello Hook the TV to DVD player with AV cable. Select AV from the TVs menu. This is the pciutr of the AV cable. It will have three wires, and you should connect it with your DVD and TV according to its instructions. OK.
Hi, In order to watch either DVD or VHS on your TV ,you need to make the following connections ..
You need to connect "DVD Player / VCR Combo" to" TV " as (Audio/video output
of DVD Player / VCR Combo -TO- Audio/Video input of TV) ..
use either "RCA analog (red/white +yellow ) " or "SCART "or
"Optic " cable.(any standard optical cable )...if exist ,optic is the best way to
connect it..Remember your DVD Player / VCR Combo 's "OUT" goes into" IN "of the TV ..
pls also
remember,wherever you connect your DVD Player / VCR Combo on your TV ,you should switch
the source selector accordingly to correspond to the connection on the
back...
Hope this helps!..if more help requires pls let me know. Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :)
Decide
what type of connection to use. Look at the back of your DVD player. It
should at least have RCA (red, yellow, white) output ports. It may also
have component out, S-video out, VGA out, or HDMI out. These
connections vary in picture quality and price, HDMI being the most
expensive and providing for the highest-quality picture. Whichever type
of connection you decide to use, you also need to verify that you have
the same connection on your TV. Flat screen TVs typically have more
connection options than other types of TVs, so you should at least have
component, RCA and HDMI inputs.
Connect
the DVD payer to the flat screen TV. Take one end of the cable or
cables you decided to use and connect to the output on the DVD player.
The other end should be connected to the corresponding input on the TV.
Video input connections are usually found on the sides of flat screen
TVs. Once the DVD player has been connected, you are ready to use your
DVD player.
Check
DVD player functionality. Tune your TV to the input that you used for
your DVD player by pressing the button on your remote labeled "input,"
"source," "TV/video," Source select," "TV/AV" or the like. For
instance, if you used an HDMI cable plugged into your TV's "HDMI 1"
input, press the input selection button until you see HDMI 1 on the
screen. Power on the DVD player, insert a DVD into the player and press
play and you should now see a feed from your DVD player.
Hi ccraigo
To answer your question;
Your motorola will connect directly(not through the dvd) to the tv set into one of the input ,(preferably using hdmi or component cables for hd) and the dvd will use a different input,
All you have to do then is switch between which one you want to watch.
Hope this help Cheers
The jacks from the player go to the same colored jacks on tv. Then after jacks are connected, tv must be on channel AV or Input. that is the channel used by the jacks. JUST MATCH UP THE COLORS.
Yuor going to have to buy a RF modulater about $20.00 at wal-mart or radio shack...instructions inside (this is the only way your DVD player will work on that TV!)
if you dont have the audio video imputs RCA jacks on your TV, you can hook it up through a RF MODULATOR you can hook up to any tv this way. they come with instructions as well as the magnavox also shows how to hook one up.
