SOURCE: Hp wireless not detecting
Just so you know, your laptop is covered under HP warranty, that model was recalled. See here and follow the instructions they will repair it for free! I just did it with mine.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=ca&docname=c01087277#c01087277_identify
good luck!
SOURCE: i have an HP laptopand a linksys wireless
I want too so here we go keep it away from the microwave LOL You may need to explain to me your isp provider because Like a house everyone has a door If it is a 802.11b you may need to get up too speed with 802.11g or 802.11n These are range based systems if you see lights on the router and internet is lit its works now you are there anywall between you and the router yes means rf interuption
like electrical or concrete walls (Bunker LOL) you need to look at the receiver on the laptop first start next to the router (PS make sure your the admin) establish connection and start walkin around or goto this site and Find what they didnt tell you.
http://www.linksysbycisco.com/US/en/support
SOURCE: HP 550 - Unable to detect just a particular wireless network
Given all the circumstances, I can only guess that, for some inexplicable, apparant reason, your network card in your computer is the culprit. Try to get a friend who has the same model to swap cards with you, then you'll know for sure. The other problem could be something to do with the signal and some slight anomoly that is causing your card a problem in detecting it. A communications signal is complicated, and some wireless modems have better circuitry than others, depending on the model. But no matter how we speculate, this is just one of those Twilight Zone enigmas! Best of luck- tricky problem, for sure.
