Touch screen non-responsive. Reset did nothing. Got to the calibration screen and got no response when I tried that. Stays on the first 'x' for calibrating. Batteries charged fine and show to be fine. From what I read in previous posts it is either a faulty LCD or ribbon cable? If that is it what are the appr cost to fix this and where?
SOURCE: Touch Screen not responding to Touch
the flexwire cable is have an openline and that line is connected to the touch screen panel...it have to repaired or replace that flexwire to the service center....in our shop we modified that wire and became more durable than the original wire......:-)
SOURCE: The buttons on my lcd screen does not work
hi, if your lcd's touchscreen is not working only,then not to worry about just replace the lcd flap and its done,its very easyly avilable and easy to replace
SOURCE: lcd problm
there is 2 types of fault for this....one lcd cable damage or touch panel damage if it is you have replace LCD
SOURCE: I have a sony handycam and I cannot calibrate my
The touch screens in these can shift. Can you rotate the screen and get the screen to work? if so it's possible if your skilled to recenter the screen then resecure it. of course you might end up having to replace it. I have replaced more of them than recentering them . Larry's Electronics [email protected]
If the issue persists, perform
a power resetting of the Camcorder. To perform power resetting, please remove
the battery pack, turn the Power switch to ON for more than 15 seconds, turn
the Power switch to OFF position and then reinsert the battery pack.
If the issue persists even after performing all the above-mentioned steps,
service is required.
