This can be accomplished a couple of ways. Depending on the model of your computer there may be a pressure sensitive switch under the mouse pad that pressing a little harder will actuate. Another method is there might be 'virtual' mouse buttons on your trackpad. Put one finger in the flower left corner and drag on the pad with another. Finally, there is a setting for a double click drag and drop. Tap the mouse pad twice and on the second tap keep your finger on the pad and move it. Good luck!
Hi Peter Hudson, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
with these new computers you use a touchpad to move your cursse so when I do surveys from Mysurveys you to touch an item to rate there perform of there product normal out of 10 thats where you drag theses item down to rate them
