20 Most Recent Logitech Webcam Questions & Answers
3answers
I have a logitech webcam with a built in
go to 'Control Panel', 'Sound', 'Recording', and select your Logitech as the default device.
12/15/2022 5:57:45 PM • Logitech Webcam • Answered on Dec 15, 2022
9answers
Cant find webcam driver
I need help find the driver for a webcam, i dont know the brandname, it olny detects that it a CIF single chip device
11/15/2022 1:55:51 AM • Logitech Webcam • Answered on Nov 15, 2022
I need driver for web camera Logitech V-UAP41 p/n 830-000062
My frend find disk with driver.
7/24/2022 10:04:52 PM • Logitech Webcam • Answered on Jul 24, 2022
2answers
My logitech webcam is blurry,
Sounds like you have a corrupt driver.
Follow the instructions below and it will work.
Disconnect the Camera from the USB port and reinstall the CD or Downloaded software program.
When the program asks you to connect the camera to the USB port, do so and it should work.
Then to use it on the Web, do this.
Web Camera's have to be setup on the program they are to be used with. Just installing the
camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype
http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/
set it up as follows:
Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
Then click on the Video Settings.
The camera, if Installed Properly, it will come up and show a video picture.
Then, on the bottom of the page click save.
The camera and audio should function properly. Your friends and Family will now be able to see and hear you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger
http://www.soft32.com/download_30.HTML
Go to Messenger at the top left and click on it.
Next go down to Preferences and click on it.
Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
Next go to the Test Audio section and (in blue writing) click on "Open the call setup assistant" and follow the instructions on the left window.
C. Windows Live Messenger:
http://download.live.com/Messenger
After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
Then on the Windows Live messenger window on the right side, click on " "Show Menus." And then click on "Show the Menu Bar".
Next go to the Menu Bar on right side, click on " "Action."
Go to "TOOLS" and click "Audio and Video Setting" and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
D. AIM (AOL) Messenger:
http://dashboard.aim.com/aim
On the VIM sign-in window click on Edit.
Then click on Settings Enhanced IM.
Next click on Enhanced IM.
Then click on Audio Video.
The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
The Audi Video drop downs are
Microphone
Speaker
Camera
The audio and camera should function now.
Additional information to use with VIM settings.
Adjust Your Audio and Video Settings:
In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently
Participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM
Conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working
Properly. Follow the on-screen prompts.
Notes:
The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button.
The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly.
images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the
Picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends.
Hope this helps. Bud
5/6/2022 1:23:06 PM • Logitech Webcam • Answered on May 06, 2022
2answers
Picture quality relic WEBCAMS.
Many factors can affect the image quality of your pictures. If you are experiencing blurry images, please try adjusting the focus ring located around the lens. This will allow you to focus the camera image on objects at different distances. Also, make sure there is good lighting. Improving the lighting conditions can improve the image quality considerably.
Connection Issues:
If the image quality is poor while transmitting video over the Internet using video enabled programs such as MSN Messenger, Yahoo! or AOL Instant Messenger, your connection speed to the Internet directly affects the image quality of the transmitted video. Corporate LAN, DSL/cable modem connections will result in the best image quality experience, while dial-up connections may result in choppy and overall poor quality because of the slower connection speed. Even broadband connections such as DSL/cable modem may experience choppy video at times because of Internet traffic or slow upload speeds. If the image appears clearly in the camera software, most likely your Internet connection may be responsible for the poor image quality in your video program.
Changing Display Adapter Settings:
If you are still experiencing a distorted, fuzzy or grainy image, you may need to change the settings for your display adapter. For optimal image quality, please make sure the video display adapter is set to display at least 16-bit high color or higher. To change the color palette please perform the following steps:
  1. Click on "Start," "Settings," and "Control Panel."
  2. Double-click on the Display icon.
  3. Click on the tab labeled Settings.
  4. In the dialog box labeled Color Palette, verify the video mode is set to 16-bit (high color) or 24-bit (true color).
  5. Also, check with the manufacturer of the video card for updated video drivers.
Low Light Boost:
If you cannot do anything to improve the lighting situation, some Logitech video cameras have an option for "Low Light Boost." If there is an option for "Low Light Boost," try enabling the "Low Light Boost" in the QuickCam software. To do this:
  1. Open the QuickCam software.
  2. At the bottom right hand corner of the camera image box, click on the arrow next to the QuickCam icon.
  3. Choose "Advanced Camera Settings".
  4. Under the Image Enhancement box, place a check mark in the "Low Light Boost" option.
  5. If that does not improve the image quality, try adjusting the other image settings, such as contrast, saturation brightness, gain and white balance.
  6. Click OK when your are done.
Using Latest Software:
Finally, make sure you are using the latest release of Logitech camera software. You can download the latest release from the Logitech Downloads + Parts page.
4/20/2022 1:51:13 AM • Logitech Webcam • Answered on Apr 20, 2022
4answers
Iprc webcam driver....
9/14/2020 11:57:53 AM • Logitech Webcam • Answered on Sep 14, 2020
Iprc nv-136m driver
this driver works: https://drive.google.com/file/d/1TYjNpxEM9DJx43jrS1DUfqs2MxR2x6lx/view?usp=sharing
9/13/2020 10:08:10 PM • Logitech Webcam • Answered on Sep 13, 2020
2answers
When I call someone or someone calls me, my voice
1) make sure your mic is set as default
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
2) Check you have DirectX 9 or later installed to support your cam
3) You may have to re-install the software - browse the photo gallery and click on your model - check out any known problems as well
http://www.logitech.com/index.cfm/405/&cl=us,en?prodcrid=405
7/24/2019 7:05:19 PM • Logitech Webcam • Answered on Jul 24, 2019
Windows 7 and windows vista
Windows 7 and windows vista are not same they have some differences Difference between window 7 and window vista is explained in this link https://www.diffen.com/difference/Windows_7_vs_Windows_Vista
3/29/2019 2:39:54 PM • Logitech Webcam • Answered on Mar 29, 2019
21answers
Driver
i need Logitech V-UAP9 PN 861170-0000 software for installation purpose.so pls allow me downloading
thanking you
4/10/2018 10:36:59 AM • Logitech Webcam • Answered on Apr 10, 2018
2answers
Logitech v-ua1 p35u3 driver
thnaks for info...htttp://sdgunung03.blogspot.com
4/1/2018 1:06:52 PM • Logitech Webcam • Answered on Apr 01, 2018
6answers
Logitech 8k89 i t e camera driver
I havent use my webcam for a long time ... it is still working but I lost my intaller to start activating it again please help
logitech 8K89 I.T.E web cam.
3/11/2018 7:18:38 PM • Logitech Webcam • Answered on Mar 11, 2018
I want Logitech-8k89-ite web cam
Copy this site and paste it in your web browser address bar and hit ENTER.
From the images, select the webcam and then download your cameras driver.
Then to install and use it on the Web, do this.
Disconnect the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Web Camera's have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
A. Skype Setup:
B. Yahoo Setup:
Microphone
Speaker
Camera
Notes:
3/4/2018 6:45:14 AM • Logitech Webcam • Answered on Mar 04, 2018
8answers
Webcam is too slow
Find a software which has good graphics for the cam n used it when using the cam
1/30/2018 2:46:34 AM • Logitech Webcam • Answered on Jan 30, 2018
Why is my video playback all...green looking and
you might a defective camera! have you tested it on another computer? if you get the same results then it is, if not then you might to look into getting the proper codecs or speak to their IT support if there is such a thing or hire a professional.
12/18/2017 4:28:23 PM • Logitech Webcam • Answered on Dec 18, 2017
Mp4 file problem
check the name of the file. right click on the file with your mouse and check the file name. sometimes the name will be the problem. if its something like videoname.TMP rename the file to videoname.MOV or videoname.AVI.
be sure to make a backup of the file before you make any changes.
good luck hope this solves your problem. if it doesn't work feel free to pm me
12/8/2017 9:28:35 AM • Logitech Webcam • Answered on Dec 08, 2017
3answers
My webcamra Name zebronics software cd missing.
Hi you can go here to download the software/driver just select the model of your zebronics and Operating system.thanks hope you rate my response
http://www.zebronics.net/driverdownloads.asp
11/28/2017 7:15:54 AM • Logitech Webcam • Answered on Nov 28, 2017
4,088 questions posted
Top Logitech Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Logitech Computers & Internet
Most Popular Question
logitech webcam hd 720p driver download
  • Computers & Internet
