NEC NP07LP Projector Lamp Logo
m
mike payment Posted on Mar 18, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to replace bulb only in NP07LP housing
Can I remove bulb from housing and replace only the bulb?
Lampdeng.com
Level 2:
Renaissance:
An user who is expert in 3 categories / brands.
  • Expert 789 Answers
  • Posted on Mar 19, 2014
Lampdeng.com
Expert
Level 2:
Renaissance:
Answers
789
Questions
0
Helped
197880
Points
977
You can only replace the bulb from the housing ,it is easy to do it
the original bulb is USD80,
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD
chip,color wheel,motherboard,powersupply,ballast... with high quality and
competitive price.
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
skype:lampdeng
Change a turn signal bulb on a 2006 dodge grand caravan
The rear remove two push in pins remove tail light housing replace bulb. Front remove screws holding head light housing replace bulb
Blinking red status light on projector won.t come on
holding down the "OFF" key on the remote control for 30 seconds
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
How to replace NEC NP 07 Lp projector lamp
lamp USD70
Have a nice day!
Jerry
Lampdeng Limited
Need to know how to change break light bulb
Open the truck & remove philips head screw that is located to the left of the tail light housing in the trunk lid weatherstripping housing area. Next unscrew the trunk lining screw to fold back the trunk lining to get at the two plastic wing nuts that hold the light housing.
Unscrew these two wing nuts and slide the housing out, then remove the bulbs and replace. Bulbs come out similarly to how you'd replace the front headlight bulbs (unplug, twist counter-clockwise to unlock and remove old bulb, replace with new bulb and turn clockwise to lock, plug back in).
3helpful
HOW TO CHANGE HEADLIGHT
  1. Open the hood.
  2. Remove push-pin fasteners from the grill assembly.
  3. Tilt the grill assembly forward and lift it up to remove it from the vehicle.
  4. Remove the fasteners from the headlamp assembly.
  5. Push the headlamp housing lever up to disengage the headlamp housing from the headlamp housing pocket.
  6. Turn the bulb socket being replaced counterclockwise one-quarter of a turn while pressing the socket in firmly.
  7. Pull the socket rearward until the bulb clears the headlamp housing, and lift it up to access the bulb.
  8. Disconnect the wire connector from the bulb by lifting the lock tab and pulling it away from the plastic base.
  9. Remove the bulb assembly and replace it with the appropriate bulb.
  10. Reverse the steps to reinstall the headlamp assembly.
6helpful
Headlights removal ford explorer 96
  1. Check that headlamp switch (11654) is in the off position.
  2. Lift hood (16612).
  3. Release latch and swing filler panel to left or right.
  4. Remove electrical connector from headlamp bulb by grasping wires firmly and snapping connector rearward.
  5. Remove headlamp bulb retainer (13N019) by rotating counterclockwise (when viewed from rear) about one-eighth turn and sliding ring off plastic base. Keep headlamp bulb retainer as it may be used again to retain new headlamp bulb.
  6. Carefully remove headlamp bulb from socket by gently pulling straight backward out of socket. Do not rotate headlamp bulb during removal. 7056091.gif
Headlamp Assembly, Explorer
Removal and Installation
  1. Disconnect battery negative cable.
  2. Remove blind rivets (2) attaching screws (4) and radiator upper sight shield.
  3. Remove turn/park lamp attaching screws (2) and pull assembly away from body. Remove bulb sockets from housing and remove lamp assembly. Repeat on opposite side of vehicle.
  4. With turn/park lamp assembly removed, screw attaching grille to front fender flange is accessible. Remove grille attaching screw. Repeat on opposite side of vehicle.
  5. Remove attaching screws (4) located across top of grille.
  6. Grip lower edge of grille and pull outward to disengage from retaining clips. Remove grille.
  7. Using needle-nose pliers, compress barbs on headlamp housing retainer. With barbs compressed, pull forward on housing just enough to disengage from retainer. Repeat on opposite side of headlamp housing.
  8. Turn headlamp housing as necessary and pull forward to disengage from headlamp aiming ball socket.
  9. Disconnect wiring from headlamp bulb socket.
  10. If replacing headlamp housing, remove retaining collar and bulb.
For installation, follow removal procedures in reverse order. Make sure to check headlamp aim. 568a220.gif
3helpful
How do you replace the drivers side headlight bulb on a 2004 New Beetle convertible?
1. Remove headlight housing. A.Open Hood and pull the release lever at the back of the housing. The headlight housing slides in and out of the body in tracks. B.Pull out the headlight housing far enough to disconnect the electric connectors, then slide the housing completely out. 2. Remove the retaining clip to remove the upper (low beam) or lower (high beam) bulb from the holder from the back of the housing unit. Remove the old bulb(s). 3. Do not touch the bulb with your bare hands! Wear clean gloves or hold with a clean paper towel. Fingerprints on the bulb will cause the bulb to burn out or explode!. Insert the new bulb. 4. Replace the retaining clips and insert the housing back into the tracks and into the body. Plug the electric connectors in and insert the housing completely. 5. Reposition the release lever to the original position being careful not to break the plasic lever. 6. Check your lights for operation.
How do you remove the head lamp assembly on a 1993
1. Make sure headlamp is off and open hood.
2. Taurus model years 1990-1999: you must remove the whole headlamp to replace the bulb. Not a horrible task. Just annoying.
3. Facing the driver's side headlamp, and looking at the headlamp itself, at clock positions 8, 11 and 1 are the headlight housing screws. They all look the same. Using a 10mm socket wrench, remove these 3 screws and set them aside.
4. Just to the right of the "11 o'clock" housing screw is a bolt (same hexagonal 10mm sized top as the housing screws). This just needs a few turns to loosen it.
5. Gently pull the whole headlight forward. Now you can get at the bulb.
6. Disconnect the electrical connector from the bulb. Now the headlamp is free to work with. Remove the bulb, replace with a new bulb, make sure the bulb housing cylinder is in place and reconnect the electical.
7. Place headlamp back into position. Line up screw holes. Tighten the bolt. Replace housing screws and tighten.
8. Passenger side headlamp is mirror image of driver's side. Screws at 11, 1 and 4 o'clock positions. Bolt should be to the left of the "1 o'clock" housing screw.
2helpful
2answers
Replace low beam on 2000 LHS
The headlight housing must be removed to access the bulbs on the back of the housing. HOWEVER!!! you must take loose the bumper on the side you are replacing. To do this you also have to take loose the inner finder and turn you wheel sharply in the opposite direction of the bulb to be replaced. There is a 10mm nut you will have to remove inside as well as multiple plastic fasteners along the inner finder and across the front under the hood. Bulb just twist out to remove once the housing is removed. Also, resist the urge to use a very large hammer. Use caution when pulling the plastic bumper out where the 10mm nut was removed, the stud can easily scratch the paint while working the housing out of its socket.
4helpful
Replace the tail light bulbs in 2004 infiniti g 35 coup
tail light bulbs are replaced by removing the tail light housings. The housings are accessed by removing the nuts, the nuts are secured behind the inner trunk liner inside the trunk. Remove fasteners holding liner in place, remove 3 nuts for each housing(i believe it's 3 nuts if my memory serves me right), remove housing and replace bulbs
Top NEC Office Equipment & Supplies Experts
Alexander
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
