Maybe you don't have your wireless turned on. Look on
both sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can toggle
the wireless on or off. Normally you would Press and Hold the FN function
key located at the lower left of the keyboard, then hit the correct F1 thru F12
key that toggles the wireless. The correct F1 thru F12 key to hit will
have the wireless signal icon )))) on it. Or it might have the icon of a tower
with the wireless signal icon )))). Normally the screen will display
Wireless On or Wireless Off when you toggle the wireless.
If you put the wrong password in, it will never connect. it will keep trying to connect but never will.
Authentication
That means you probably don't have the password or the
Authentication Type set correctly.
For Windows XP below:
Click Start/Control Panel/Network Connections then Right Click on the Wireless
Network Connection and select Properties. When the Properties window open
click the Wireless Networks tab. Click on the SSID for your wireless
network that you connect to and the Properties window will open. You can
change the Authentication Type to match the type set in your wireless router
and you can also change your password or Network Key to make sure you have it
in correctly.
For Windows Vista below:
Click Start/Control Panel/Network and Sharing Center then look to the left of
the open window and click Manage Wireless Networks. Find the SSID of the
network that you connect to and double click it. When the window opens
click the Security tab to change the Security Type (which is the
Authentication), The Encryption Type and the Network Security Key (which is the
password).
For Windows 7 below:
Click Start/Control Panel/Network and Internet/Network and Sharing Center then
look to the left and select Manage Wireless Networks. Find the SSID of the
password).
