Cobra 29 NW LTD Classic wont calibrate and red antenna light keeps coming on
The calibrate knob only calibrates the radios SWR meter, the owners manual will show you the procedure for that. If your ANT light is coming on, it is telling you that your SWR is to high, and may cause damage to the radio from reflected power. You should purchase an in line meter as the radios internal meter may be somewhat unreliable. You need to tune the antenna to the lowest SWR possible. Typically anything under 2.0:1 is acceptable. Radio Shack sells a meter for about $50, and is pretty accurate. Antenna mounting can also cause high reflection if it is to close to other objects. Google "CB antenna tuning" or read the instruction manual for you antenna, and you should be able to figure out how to properly tune the antenna.
