Thomson CR460CD Clock Radio Logo
A
Anonymous Posted on Feb 26, 2014
HOW TO SET ALARM THOMSON BLUE TOOTH CLOCK RADIO
How to fix the alarm for Thomson Model CRD-2196A iPod DOCKING, clock, radio, CD unit.
There is no way. The alarm is electronic. The only thing you might try is spraying the alarm buttons with electrical contact cleaner.
You could contact them and see if they would repair it.
https://images-na.ssl-images-amazon.com/images/G/01/00/00/05/00/21/30/500213070.pdf
1helpful
2answers
How to set presets on nelsonic clock radio nlc 618
To set this alarm first ensure that when you press the Mode button several times the FM/AM radio does not turn on . If the FM or AM radio does turn on or the lcd displays "AU" press the Power button that is next to the Mode button 1 time (pressing the Power button toggles you between 2 settings). You should now be able to press the Mode button at least 3 times without the FM/AM Radio turning on.
Next you press and hold the Alarm 1 or Alarm 2 button and (while continuing to hold down one of the Alarm buttons) press the Hour or Min buttons to set the time of whichever alarm button you are holding down.
When you have the alarm time set you can release the Alarm 1 or Alarm 2 button and press the same button (do not hold the button down this time) to cycle between the types of alarms you can use. You will see the blue circle indicator move between Buzz and Radio when pressing the buttons (Blue circle on left side is for Alarm 1 and blue circle on right side is for Alarm 2). There is a third option as well but I'm not sure what the alarms will do if you set them to it because the blue circle indicator disappears entirely after cycling to Buzz and then Radio.
Hope that helps!
Need a copy of manual for a Panasonic 500 dual alarm clock radio
You may be able to find a manual by calling the Panasonic National Parts Center directly at 1-800-332-5368 9am-8pm EST during weekdays.
How do you set the alarm?
I couldn't find a manual for this model, but you might be able to get information from the manufacturer. This information is from the GE site here:
In 1987 GE sold its home electronics business to Thomson®, Inc. For a time, Thomson® produced many products that carried the GE name, but now only manufactures telephone and communications products.
The items that they support but no longer manufacture include:
  • Audio products
  • Camcorder
  • Cassette recorder
  • CD player
  • Clock radio
  • Spacemaker radio
  • Spacemaker TV
  • Television
  • Video camera
For assistance with any of these older products or your current GE telephone products please call 1-800-447-1700 in the US. In Canada, call 1-800-522-0338 (English) or 1-800-522-0445 (French).
Thomson, Inc.
PO Box 671988
Marietta, GA 30006-0034
Try calling the phone number listed. They might be able to supply you with a copy of the manual. Hope this helps a little. Thanks for using Fixya!
NEED A MANUAL. WAS GIVEN A RCA RP3710A CLOCK RADIO, USED. NEED A MANUAL TO SHOW ME HOW TO SET AND RUN
Thomson / Alcatel - Technical support Contact Number Try there support. This is a UK one, if you are in USA go to the website for local number.
Telephone number for Thomson / Alcatel - Technical support:
Thomson / Alcatel - Technical support Telephone Number: 09063022114
Thomson / Alcatel - Technical support Contact Number: 02073090226
4helpful
2answers
How do I set the clock on my Ranger professional with Blue Tooth
Press dimmer switch 3 sec, then when first two digits (hour( of clock flashes set hour using Phone Volume switches. Press dimmer again to set minutes, then when done press Dimmer once more to activate the clock. It displays in military configuration (e.g., 1:30 PM will read as 1330 Hrs) See user manual page 8
1helpful
Thomson RR520U Alarm Clock
Hi, Same here but I DO have the manual. Still took a lot of working out tho. Make sure you have decent batteries installed (Should be changed every year) so that the time will remain next power out.
If you send me your Email address I'll copy the relevent page for you. To rizla01 - at - yahoo.com
Top Thomson Audio Players & Recorders Experts
SmartAviator
SmartAviator
 Mikey
Mikey
Bob Kirkwood
Are you a Thomson Audio Player and Recorder Expert? Answer questions, earn points and help others
