20 Most Recent
Thomson RP5600 Clock Radio Questions & Answers
Thomson RR520U Alarm Clock
Hi, Same here but I DO have the manual. Still took a lot of working out tho. Make sure you have decent batteries installed (Should be changed every year) so that the time will remain next power out.
If you send me your Email address I'll copy the relevent page for you. To
rizla01 - at - yahoo.com
I can't set the clock
I had the same problem. Looked here for help and found no solution, so dug through the attic till I found the manual. Thankfully I had kept the box. Here's the instructions from the manual:
Setting the Time
- Press the SET button, the ":" will flash on the display.
- Press REV or FWD to set the time.
- AM or PM icon will show beside the time.
TIP: No icon will be flashing if all selectors are set, if you see any icon flashing on display, press the
SET button repeatedly to confirm everything is set correctly.
LCD light broke after one day
Probably something came loose inside. Most likely the wire that powers the lcd came loose. It's possible it shorted out too. Personally I'd return it and not take it apart. If you can't fix it you'll void the warranty and the store might not return it if they see it's be disassembled. You're better off exchanging it since it's already had an issue after one day. It may be an indication of the workmanship of that unit in regards to it's longevity.
I hope this has explained your question in detail. If I've helped you please don't forget to rate me.
Peter
