20 Most Recent Thomson Lyra PDP2444 53 MB MP3 Player Questions & Answers
Found your question due to having the exact problem you described. New firmware, format... loaded new music, same problem. While switching to yet another set of headphones the sound got better momentarily. The case doesn't appear loose, but squeeze right next to the lcd and lyra name and the audio was fixed. For some reason the audio was mechanical sounding and the voice was almost non-existant unless pressure was placed on the player where described. I tightened the screw in the retaining strap hole and the one under the USB connector flap and all is well for now. Good Luck!!!!
Thomson Lyra... | Answered on Nov 28, 2012
Preformat : By Fix-shad0w
#1
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
Thomson Lyra... | Answered on Aug 27, 2010
Enter the number and chose download driver in the page below:
Download driver Thomson Lyra PDP2444
Thomson Lyra... | Answered on May 21, 2009
Hello Jan, tell us what model is your portable CD player Thomson
I wait your answer
Greetings Franco Dosil
Hola Jan, comenta que modelo es tu portable CD player Thomson
Espero tu respuesta
Saludos Franco Dosil
Thomson Audio... | Answered on Jun 18, 2019
Murdo's tip to trim off the cover of the AA battery base to expose a few mm of metal is spot on. Replacement rechargeable batteries for my Thomson wireless headphones did not charge, no green light, utterly frustrating, till I read Murdho's suggestion. Thanks for that
Thomson Audio... | Answered on Oct 02, 2018
A "Remote code" for what "device" to talk to your thomson x101b??
Thomson Audio... | Answered on Feb 10, 2018
http://www.thomsonaudiovideo.eu/
It might be a french product . Not sure if you need to speak french but you could ask them if there is a user manual ?
Maybe use a translator web site and put french in as well in your request .
Thomson Audio... | Answered on Jan 25, 2018
Thomson Lyra PDP2444 53 MB MP3 Player Logo
Popular Tags
19 questions posted
Top Thomson Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Thomson Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Thomson Audio Players & Recorders
Most Popular Question
dont disc install device
  • Audio Players & Recorders
