I just set up converter box and set it to scan programs for set up. After I turn off tv, converter box & audio home theater for the night, it must be rescanned to pick up channels. Then, the antenna must be repositioned every time I change the channel. How can I get the tv to stay set on the channels I originally scanned & selected?
You may have several problems. If you are using a indoor antenna, upgrade to a outdoor antenna. The indoor antenna has to be adjusted every time you change a channel. If you plan to sit in a chair and never move when watching tv, you may be able to pick up a channel or two. Get a UHF/VHF antenna from a home improvement store. The big box electronic stores are selling a digital antenna. There is no such thing. The antenna doesn't know if the signal is digital or analog, it just picks up uhf and vhf signals. The other problem could be that the box is bad if it is not saving the scan. I would check the antenna first from what you said though.
