Televison & Video Logo
A
Adela Sinclair Posted on Feb 15, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a regular tv for my ROKU device and new Netflix account. I need to activate Netflix for ROKU. How can I do that?
Jack Bowser
Level 2:
New Friend:
  • Expert 168 Answers
  • Posted on Mar 08, 2014
Jack Bowser
Expert
Level 2:
New Friend:
Answers
168
Questions
Helped
67434
Points
440
Go to add channel on your roku add netflix when active it
here is the link to help
https://help.netflix.com/en/node/314
4answers
Will a roku work with netflix
Netflix Activation with Roku devices
  • Make sure that you enter Roku activate devices and also incorporated with the 5.1 audio options.
  • These 5.1 audio options are required for streaming of high quality contents.
  • So ensure your Roku device comes with these 5.1 audio options to enjoy high quality screening.
  • All the devices have Subtitles and captions as a default options.
  • Netflix avail users with Parental controls options and they can set their own Individual Profiles.
  • For Roku 1 model Go to Home screen > Select Netflix. You can visit channel store and your preferred Movies and TV shows are selected from there. Once you selected your preferences choose Netflix and add channel option is clicked to add your favourite shows.
  • In case of other Roku models, Go to Home screen > select Netflix. Go to channel streamed and then select preferred Movies and TV shows. Select the SignIn option from home screen activate Netflix in Roku to stream your preferred contents.
Signing out of Roku
Make sure that you enter Roku activate devices and navigate to Roku Home menu by pressing the home button. Select the Setting and choose Netflix settings from the menus. Select Deactivate the player from the Netflix account and chose the option yes now your Roku device will be deactivated.
Need an activation code to enter into my netflex account.. where do I find it?
Before you can use any channels that require a code, and a subscription, you will first need to setup a Roku account.
Which can be done here: https://my.roku.com/signup
When you finish that, you will need to link each of your Roku devices to that account. The code given from your device to link to your account, can be entered at this address: https://my.roku.com/link
Now you can add channels like "Netflix" from the Roku Store to your device. When you've added a channel to your Roku, you've only added the linking app, or it's icon, to your channel line-up.
* The first time you try to run any channel requiring a code to function properly, you should see a screen on your television, from the Roku device, which provides both a linking code, and a corresponding web address. Enter that code at the web-address given, in a browser on your computer.
Or sign into your Netflix account, and this is the address needed to link your device to Netflix: https://www.netflix.com/Activate
That's where you can enter the specific code to link your Netflix account to your Roku account.
If you ever need to add additional devices to your Netflix account, simply sign in to your account on-line... Go to account settings, and look for add a device.
To summarize,
1. You first need to setup a Roku account.
2. Next link your device/devices to that Roku account.
3. Add channels requiring subscription from the Roku Store.
4. Link those subscription channels to your Roku account.
Apr 12, 2015 • Roku 3
2answers
How do I setup Netflix on my tv?
Few Solutions:
- Connect your PC as an extra monitor and watch Netflix through browser
- Buy Google Cast device and cast Netflix from your mobile device to your TV (Cheapest way)
- Buy a smart TV that has Netflix installed
- Buy a media box (Like Roku), connect it to your TV, install the Netflix app via the Roku channel store
Netflix member log in
you need router wich support openvpn check your router model number with dd-wrt.com and see if you can change the frimware and get openvpn software on it , if this compatible then you need vpn account you can grab from http://www.overplay.net/#a_aid=vpnprovider
May 02, 2014 • Netflix
2answers
Netflix not working with receiver
Fix Netflix Will not working on Smart TV
At the point when you utilize your Netflix account on your Smart TV, for example, Vizio Smart TV. Adhere to these directions to fix your brilliant TV's Netflix Error code, which is a workaround for Netflix not working on Samsung Smart TV.
Go to Settings
More
Help
Self Diagnosis
Reboot Smart Hub
Follow the arrangement procedure -
Trust that the arrangement will wrap up
Snap the Applications fasten and afterward follow the headings to re-download the applications.
This should fix the Netflix error message on your Smart TV.
Fix Netflix not working on Roku with the contact of the experienced team.
Source URL : https://www.rokuerrorcode009.com/netflix-not-working-on-roku/
Dec 14, 2013 • Netflix
57helpful
2answers
Roku Customer Service Call 1-8O5-225-669O We are 24 Hour Available Call for Setup-Install-Fix Error.
Hi! I am roku product representative, You need to put the activation code from your roku to your roku account (if you have one) and just in case you don't have any roku account yet, you may create one or you may call a roku product representative 1-888-600-7658. thanks!
BEEN TRYING TO CONNECT MY ROKU BOX FROM NETFLIX
You will need an account with Netflix. Once you have your Netflix account on your Netflix account page, you will see a heading "Watch instantly on your Tv", under that heading you will see a link to "Activate a Netflix ready device".
4helpful
2answers
Want to activate my Roku Netflix Player; can't seem to find proper place to enter code from TV Screen to activate my account
WWW.NETFIX.COM/ACTIVATE
Don't worry I will help you.
First
You must on your Roku player & Your laptop.
Play netflix2_bing.gif again then its says enter code .
Follow these steps
1. Sign in to your netflix account on your pc then you see right hand on the top of side my account & help click there.
Scroll down & you got these options on the page.
WATCHING INSTANTLY ON YOUR TV OR COMPUTER
* Activate a Netflix ready device
then click here you get code. You should paste this code to your roku netflix
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
