Question about Technics SA-DX1040 Receiver
I am a woman, an elderly one at that. i am trying
I am a woman, an elderly one at that. i am trying to connect the roku to a tv. i have a router connected in another room, but i can't get the roku to establish a connection to the internet. netflix site says enter a "code" found on my tv screen to activate player. where in the world is that?
    New Friend:
  • 48 Answers
Don't worry I will help you.
First
You must on your Roku player & Your laptop.
Play netflix again then its says enter code .
Follow these steps
1. Sign in to your netflix account on your pc then you see right hand on the top of side my account & help click there.
Scroll down & you got these options on the page.
WATCHING INSTANTLY ON YOUR TV OR COMPUTER
* Activate a Netflix ready device
then click here you get code. You should paste this code to your roku netflix.
Posted on Jun 09, 2010
6ya staff
SOURCE:
How do I fix my Roku that no longer allows me to stream anything on my TV?
Did you contact NETFLICKS ABOUT THE PROBLEM ,I could see an occasion error but not for two weeks !
What model ROKU do you have?
If you can't stream anything you could have a bad connection on Roku plugs or a bad router sending the signal,are you sure your wifi router is on. How is router connected to your tv,wireless or yellow Ethernet plug?
Feb 14, 2016 | Roku Televison & Video
When I won't connect with my tv its say unable to connect to roku .(error cod 011)what that mean ?And what I hove to do
You have to temporarily disable your wireless router firewall to connect your Roku the firewall is blocking the Roku. If you have a Roku that has an Ethernet connection you can just plug an Ethernet cable from the Roku to to Router.
If your provider, Comcast etc.., provided the router call them and they will assist you. If you purchased the router it should be in the manual how to access the settings.
Jan 17, 2015 | Roku Streaming Stick
Cant connect to the wireless net work
You probably have a slow internet connection. It is recommended that you have a minimum 25/25 Mbps connection from your provider. If you do then the Roku might be too far from your wireless router. Try to move the router closer to the Roku if possible. The best way to watch streaming video is with a wired Ethernet connection with a Roku 2 or other wired device.
Nov 28, 2014 | Roku 2 XD Streaming Player 1080p (3050R
How do I set up Wi-Fi?
First, you will need you network password, if password protected. Next, connect your Roku device to the television nearest your router.
Start your Roku device, and wait for the Roku main-screen to appear. Then scroll down to "Settings" and hit "OK" on your Roku remote. Next scroll to "Network" and hit "OK' on your remote, then choose wireless, or wired. If you using an Ethernet cable to connect your Roku, you won't need a network password. If your trying to make a wireless connection, this wireless choice is where you'll need your network password.
Nov 17, 2014 | Roku XDS Streaming Player 1080p Wireless-N...
How can I enter password in roku 3 I don't know how it connect and not work
I have created this document that will step you through the setup and also enter your password for your network. Hope this helps you.
Follow these steps to setup your Roku player 1. Connect to your TV
  • Use a HDMI cable. Connect one end to the HDMI port of the Roku player, and the other end to an available HDMI input on your TV.
  • Make note of the TV input used.
2. Power up key components
  • Open the battery compartment and carefully insert the provided batteries into the slots, following the correct battery orientation.
  • Power up the Roku player by connecting the provided power adapter to the Roku player and to an available wall outlet.
  • Turn on your TV and select the correct TV input.
3. Connect to your network
  • If you are using a wireless network, select "Wireless" as your network connection:
  • Select your network from the list of available networks.
  • Enter your wireless network password when prompted. (Note: passwords are case-sensitive)
  • If you are using an Ethernet wired connection, select "Wired (Ethernet)" as your network connection.
4. Complete guided setup
  • Get the latest software
  • Your Roku player will let you know if there is a software update available, and will restart after the update
    is complete.
  • Link your Roku player from any Internet browser
  • A link code should be displayed on the TV screen after restart
  • Using an Internet browser, follow the instructions to link your Roku player to a new or an existing Roku account.
Help for common setup mistakes and solutions
Symptom
Possible causes
Try these!
I don't see any picture on the TV
TV is OFF
Cable loose
Roku is OFF
Wrong TV input
Ensure TV is ON (it's more common than you think)
Check all connectors are snugly in place
Check power adapter is snugly connected, and wall outlet is working
Select the correct TV input
I can not connect to wireless network
Weak wireless signal
Wrong wireless name
Wrong wireless password Wireless name hidden
Move Roku player location (even a few inches may help)
Ensure correct network name selected
Ensure correct password entered
SSID can be hidden, use "Add Network" from wireless network screen
My remote does not work
Not in line of site
Batteries weak
Get closer and ensure there are no obstacles between your remote and the Roku player
Try a fresh set of batteries
Resolving wireless connectivity
If your Roku player isn't connecting to your wireless network, try the following:
Description
Do this
Tips
Repeat guided setup • •
Go to Settings>Network>Wireless•
If "Update connection" is available, select it to refresh your connection
If not, just select your wireless network from the list, enter your wireless password when prompted
If you were previously and just lost connection, you may not need to enter your password again
Passwords are case-sensitive
Restart the Roku player and • your wireless network
Unplug the power connector from • the back of the Roku player
Unplug the power connector from the back of your wireless router
Unplug the power connector from the back of your modem
Plug the power connector back into modem (wait a couple of minutes for it to fully boot)
Plug the power connector back into the wireless router (wait a couple of minutes for it to fully boot)
Plug the power connector back into your Roku player, and wait for the image on your TV
Follow repeat guided instructions above
Your wireless router and modem may be combined as one device
Factory reset the Roku player
From the Roku home screen, sele•ct Settings>Factory reset and follow the instructions
Note: You can also reset the Roku• player using the reset button. Find the reset button on your Roku player, press and hold for 15-20 seconds ( the front LED will rapidly blink a few times)
Factory reset should be used as the last resort, if all other steps failed to recover functionality
After a reset, you will need to relink your Roku player to your Roku account, and setup subscribed channels with username and password, if applicable
If you forgot your password, you can recover it here at this URL:
Forgot Password
A new password will be sent to the email account listed in your account. If you do not see the email, be sure to check your spam filter.
Sep 12, 2014 | Computers & Internet
I reset my roku 2 and now it will scan for and find a wireless connection to connect to however will not connect, the light that usually flashes while it is trying to connect will not flash... I can't even...
Ok first try these step process if you have:
Roku 2 (Model 2720) - http://support.roku.com/entries/27936640-Roku-2-Model-2720-Setup-Instructions
Roku 2 XS(Model 3100) - http://support.roku.com/entries/27940370-Roku-2-XS-Model-3100-Setup-Instructions
Try to reboot again if still have problem and after all Roku will not connect than try to reset your router or configure your router with your ISP. For router configuration and set-up Linksys Support .
Jun 04, 2014 | Computers & Internet
I need to ete the activation code for my roku 2 streamind device on my computer
Hello friends...
Restart your Roku device and your router to connect with Roku:
1. To restart your Roku player, go to Settings > System > System restart. To restart your Roku TV, go to Settings > System > Power > System restart.
2. To restart your router, check the instructions from your ISP or router vendor.
For any help visit us: Roku Com Link
Feb 26, 2013 | Roku 2 XD Wireless Video Streaming Device
I connected my vizio 55 inch wireless enabled tv to a new Netgear N600 router, previously I had an older version of a router, now I cannot setup to connect to the new router
I to just upgraded to the Netgear N600 router. No problem with my iMac or 3 Roku boxes in three different rooms, but would not connect to my 22inch Vizio WiFi in the kitchen even though it could see the signal. After 3 days looking on the net, I gave the guest setup on the router a try. It worked! the Vizio sees both signals. Just select the Netgear "guest" and enter the password you set it up with. Works like a charm.
Jul 18, 2012 | Vizio XWR100 Wireless Router
I AM TRYING TO INSTALL ROKU FROM MY PC TO A TV IN ANOTHER ROOM. I HAVE DONE EVERYTHING EXCEPT GET THE CODE IN THE ROKU ACCT. BUT CANNOT GET ROKU TO ACCEPT IT.
I need some info first.
1) Are you connecting by wireless connection to your roku device?
2) are you trying to input the roku code on their website, or are you trying to connect to a wireless access point with your device?
Oct 06, 2011 | Roku XD Streaming Player 1080P Wireless-N...
Not sure if router is sending signal to roku
Go to the settings menu, then Network, If the Roku sees your network all you have to do is put in the WEP key to connect to your home wireless network. If the Roku does not see your home network try moving the router or the Roku away from any heavy metal in the room, (ie fireplace, or objects). Hope this helps FixYa up.
May 23, 2011 | Belkin F5D9231-4 Router
Technics SA-DX1040 Receiver Logo
659 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
