LG WM-2277HW Front Load Washer Logo
A
Anonymous Posted on Feb 16, 2018
Washing not perfect
I hav problem with the efficiency of my machine... It's been a year since we bought it n not yet serviced... After washing, the clothes losing its whiteness n also the dirt not getting washed off... Is t because the filter s full n there it gets mixed with the washing water??? Please help
john wesley
Level 1:
New Friend:
  • Contributor 39 Answers
  • Posted on Feb 18, 2018
john wesley
Contributor
Level 1:
New Friend:
Answers
39
Questions
0
Helped
18494
Points
92
Change the filter alone u will receive the better result.
5 Related Answers
Anonymous
  • 15 Answers
  • Posted on Jul 19, 2007
SOURCE: LG WFT851 - Flakes of dirt problem
try putting some milton or baby bleach into the machine with the hottest possible wash with no clothes with the highest water level
ginko
Ginko
  • 19396 Answers
  • Posted on Jan 08, 2009
SOURCE: LG TROMM washing machine can't open door
You need to unplug the machine, and drain the water from the drain hose, accessing the drain pump.
Once you access the drain pump also remove all obstructions in drain lines, this often fix teh problem.
If you do not have done anything similar before, then it is better to call the technician.
Anonymous
  • 3741 Answers
  • Posted on Aug 20, 2009
SOURCE: washing machine will not drain. water wont drain
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Anonymous
  • Posted on Sep 16, 2009
SOURCE: LG WM2355C water leaking under machine after washing finished.
I had this same problem and it was not the supply connections or filters! Under the machine is a rubber bellows. The bellows had sprung a leak. The part was about $10 from Sears and I repaired it in about 30 minutes. The machine is heavy so be careful. Get a friend to make sure the machine won't rock or tip when you're making the repair.
Anonymous
  • Posted on Jul 18, 2010
SOURCE: My LG washing machine is flashing PE
stops washing
What year was the kenmore110 42926 he3 washing machine built
The Kenmore 110.42926 HE3 washing machine was built in 2005. This washer model was part of Kenmore's Elite line and it has a variety of features such as 5.0 cu. ft. capacity, front-loading, high-efficiency (HE) and a variety of cycle options.
It's worth mentioning that Kenmore is a brand owned by Sears, so the model number is not an indicator of the year of production, but the features can give you an idea of the era it was built.
1helpful
Will not start
You hav eto call the company you bought the washing machine from.
1helpful
Hi I have samsung top loader washing machine.Now i could here some water sound inside the washing machine when is shake the washing machine i.e below the tub..I just want to know what is the problem...
the inner bowl has whats called a balance ring which means the top layer ring around bowl has water inside to keep washer balanced...this is perfectly normal
Year old front loading ge washer door won't open after washing towels. i can't find manuel or model number on machine, but what it does say on machine is: GE 10 cycle/super capacity plus/ 4 wash spin...
Love this service. Your technician, Lee was right on it and solved the problem quickly and efficiently. Within 15 minutes my washer was up and running again. He even suggested additional things I might do to keep the problem from occuring again. Rather than the expense of a repair person coming to my home, Lee affordably solved the problem. I will use your service again. Thanks.
1helpful
Hi my washing machine fills with water and washes but it will not spin and release the water
Peace Friend,
ngfam1 At your service!
The only way to find and to repair this is,
First unplug the washer and wait a few minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem GREAT!!! WE WIN!
How old is the washer. If it's within a year of the time you bought it you have it under warranty?
If the appliance is 10 years old or more you may not be advisable to put good money into bad! New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
You need a hands on tech for this repair!
If not only a trained laundry tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
Below I referred you to a great service nation wide!
If none of these tasks remedy the problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
I keep getting DE coming up on my washing machine screen and it wont start
Electronic problem. just call service before it cost you real money!.
If its 10 years old or more don't put money into it!
The new ones are much more energy efficient!
Try these guys,they are good!
A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Neil
Washer won't fill for the rinse cycle
For this problem you should call service.
If it's 10 years old or more, better off replacing it with a newer machine which will be much more efficient!
Try :
A&E Factory Service
1-800-905-9505
Nation wide / 7days/24 hours
Good work
Please give me a solution solved rating in this site
Thank You
Neil
3answers
Crosby washing machine has lint issue,,,my cloths gets linted,,,how to fix this,,,this machine is upward loader,,,has no window for lint remove
Hi khan,
Happy to be of assistance for you!
sounds like this time you need to,
call Service and have them come out.
If it's new your our under warranty for 1 year!
If it's 10 years or older then do not waste the money .
The newer ones are more efficient!
Good work done here.
A&E Factory Service
Nation Wide
7days/24 hours
They do Frigidaire warranty work.
Thank You for asking!
Please rate my, solution solved in this fixya site!
Neil
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
