20 Most Recent Samsung SW62ASP Top Load Washer Questions & Answers
The inside drum has dropped. What could be the
the suspension rods have busted if your handy enough you can undo a few screws take the top off & change them yourself its quite easy to change the rods they just clip in & out.make sure the power is turned off & the plug is out of the socket so you don't get zapped.
10/13/2021 2:00:20 AM • Samsung SW62ASP... • Answered on Oct 13, 2021
0answers
0answers
Samsung SW81ASP trips circuit breaker on SPIN cycle :(
Just had a samsung repair tech come out today to fix this issue. He said the issue is the breaker. They can not run on a D breaker. Need a GE or Seeman's breaker. That is what he said. I guess we'll see if that fixes the problem.
2/15/2017 10:09:58 PM • Samsung SW62ASP... • Answered on Feb 15, 2017
I have a Samsung Sw62asp
You can remove the front kick panel and remove the tub to pump hose to clean it out. You also have very easy to access from rear of washer
Check that the motor transmission coupling is not coming apart as well. You should never have to remove the tub, this is a very time and labor intensive job.
12/29/2016 7:46:13 PM • Samsung SW62ASP... • Answered on Dec 29, 2016
My washing machine top loader once reaches the spin cycle, with 21minutes time remaining, it goes back to rinse and repeats the cycle. What is the problem of my washer and how do I fix it? Thanks
If the washing is not distributed evenly by the time it reaches the rinse/spin cycle, it goes back to rinse cycle. Be present at the machine when it reaches the spin cycle. observe the drum to see if it is of balance and swaying to the sides, if so distribute washing evenly. Usually happens if there is a big garment or more with smaller items, Regards Phillip
12/26/2016 8:52:08 PM • Samsung SW62ASP... • Answered on Dec 26, 2016
Agitator only going in one direction
either clutch pawl tip broken or fallen off or capacitor fault
11/20/2016 12:13:03 AM • Samsung SW62ASP... • Answered on Nov 20, 2016
I have purchased a samsung sw70g9 topload model.my probem is that when water fills the tub it will drain automatically as well in the drain hose..i need an answer please help.thankyou.
A drain valve that is supposed to close according to the setting on the machine is not doing so, probably due to a problem with the circuit board or with the solenoid that closes the drain. You need in person diagnosis. I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
7/10/2016 6:20:36 PM • Samsung SW62ASP... • Answered on Jul 10, 2016
SOMETIMES THE MACHINE DO NOT RINSE OR SPIN? I EXPECT THAT THERE IS SOMETHING WRONG WITH THE SETTINGS?
I am seeing alot of these questions regarding samsung washers they are usually very good I am thinking there is too much weight in your washer, are you filling the washer too full, they can only handle so much weight before they just throw themselves into error codes. So if its clicking hit the power button does it drain the water, i am asking to see if the pump is working, if it drains , when its done unplug the unit wait ten minutes and plug it back in and turn power on, dont hit any other buttons what does it do?
5/2/2016 8:26:43 PM • Samsung SW62ASP... • Answered on May 02, 2016
SAMSUNG E3 ERROR CODE
ne3 error code
1/29/2016 11:12:07 PM • Samsung SW62ASP... • Answered on Jan 29, 2016
Samsung SW62ASP Top Load Washer Logo
327 questions posted
Top Samsung Washing Machines Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Washing Machines
Most Popular Question
error code 1e samsung top loader
  • Washing Machines
