Canon PowerShot S2 IS Digital Camera Logo
A
Anonymous Posted on Feb 05, 2014
Cannot link to PC with USB cord to down load pictures display error code E 000225
Intuitive type. error code 241 appears what does this mean and can i fix it myself
Hi i googled error code on fisher and paykel and found this link-->
http://www.searspartsdirect.com/washer-repair/error-codes/fisher-paykel-aquasmart-top-load-washer-error-codes.html
If you scroll down the page in the link the error code 241 says
"Motor control module failure", Unplug the washer and replace the motor control module. OR
"Display module failure", Unplug the washer and replace the display module...... Good luck...
HP 8250 has error 0xc18a0206
HERE IS WHAT YOU SEEK
Issue: error code appears on the printer display.
Solution:
Step one: Reset the printer
Press the On button to turn off the printer.
Unplug the power cord and universal serial bus (USB) cable from the back of the printer.
Wait 30 seconds.
Plug the power cord back into the printer.
Press the On button to turn the printer on.
If the error message does not display, the issue is resolved; reconnect the USB cable and resume using the printer.
If the previous steps have not cleared the message, continue to the next step.
Step two: Download and install firmware update
Go to the product support page to download the update.
http://h10025.www1.hp.com/ewfrf/wc/softw...
Click Software & driver downloads.
Click on the appropriate operating system link.
Click on the Recommended update to fix long power-on cycle and error codes and follow the instructions to download the file.
After downloading is complete, disconnect all other USB devices from the PC. Make sure the product is powered ON and plugged into the USB port.
With the printer directly connected to the PC, click the downloaded file FirmwareEnable_Release.EXE.
Click Open/Run.
Click OK at the Update successful window. The error should have been cleared from the printer display.
If you get a message saying a device was not detected (see Figure 1), make sure the printer is powered ON and the USB cable is connected to both the printer and PC and try step five again.
Hp 8250 ink system failure
This from the hp site: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00719450&tmp_track_link=ot_recdoc/c01369688/en_us/c00719450/loc:1&lc=en&dlc=en&cc=us&site=null&product=443024&key=null
Issue The message 'Ink system failure ' and an error code display on the product's control panel. Solution Step one: Reset the printer
  1. If the product is on, press the On button to turn it off .
  2. Unplug the power cord and universal serial bus (USB) cable from the back of the product.
  3. Wait 30 seconds.
  4. Plug the power cord into the product.
  5. Press the On button to turn on the product.
  6. If the message does not display again, you do not need to continue troubleshooting. Reconnect the USB cable, and then resume using the product.
  7. If the error message displays again, continue to the next step.
Step two: Service the printer If you have completed all the steps listed above and are still experiencing a problem, service the product.
You could also try resetting the printer:
Introduction A soft reset, also known as an electrical reset, can be used to restore the printer to a ready condition when a cartridge, paper, or other printing issue occurs. Reset the printer Figure 1: Back of the printerc00392035.jpg 1 - Power cord port 2 - USB cable port
  1. If the printer is not off, press the Power button to turn it off.
  2. Unplug the power cord from the wall outlet.
  3. Unplug the power cord from the back of the printer.
  4. Unplug the universal serial bus (USB) cable from the back of the printer, if connected.
  5. Wait 30 seconds, then plug the power cable back into the wall outlet.
  6. Plug the power cable back into the printer.
  7. Press the Power button to turn the printer on.
  8. Ensure that the memory card has been removed from the memory card slot.
  9. Make sure plain paper is loaded in the In Tray.
  10. Press the Menu button.
  11. Press the Up/Down arrow button to display the Tools menu.
  12. Then press the OK button.
  13. Press the Up/Down arrow button to highlight Print a Test Page.
  14. Press the OK button.
  15. If the test page prints, re-connect the USB cable to the printer.
If the machine does need to be serviced, here's a link to hp worldwide:
http://welcome.hp.com/country/us/en/wwwelcome.html
Good Luck!!
1helpful
HP c6180 error oxc19a0035
Issue An 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The all-in-one cannot copy, receive faxes, or print. Solution
  1. Press the On button to turn the all-in-one off.
  2. Unplug the power cord from the back of the all-in-one.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the all-in-one.
  6. Press the On button to turn the all-in-one on.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved. If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the all-in-one.
  1. Without turning off the product, disconnect the USB cable from the rear of the product. NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ). Figure 2: Example USB connection (your product might not look exactly the same as this example)c01651067.gif
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Service the product
I has an issue with my Photosmart C8180, it shows Ink System Failure-- I tried it online but did not find it, Is there no Resolution available for it, Please help me with it,
Issue: An Ink system failure message and error code appears on the printer display.
Solution:
Wait 30 seconds.
If Ink system failure does not display, the issue is resolved; reconnect the USB cable and resume using the printer.
Click on the Recommended update to fix long power-on cycle and ink system failures link and follow the instructions to download the file.
Click Open/Run.
If you get a message saying a device was not detected (see Figure 1), make sure the printer is powered ON and the USB cable is connected to both the printer and PC and try step five again. Source(s):
While down loading Video on PC the video
Using FireWirecable & card will be the absolute solution.
-Stable,trouble free data transfer during video capture.
-Video transferred at its maximum resolution 720*576 pixels or something like that compared to 340*240 via USB transfer.
-100% supported by any video editing program,even the simplest Window Movie Maker.In other words,forget Sony's software - use something else that wouldn't run you.
Of course,the cable&card might be not very globally available like USB device.But still easy to find and relatively cheap to buy anyway.
HP8250 printer would not recognize a new cartridge as new/full. Bought another today and installed. The new-new cartridge causes the same error.
Solution:
Wait 30 seconds.
http://h10025.www1.hp.com/ewfrf/wc/softw…
Click Open/Run.
If you get a message saying a device was not detected (see Figure 1), make sure the printer is powered ON and the USB cable is connected to both the printer and PC and try step five again. Source(s): Full instructions found on...
http://h10025.www1.hp.com/ewfrf/wc/docum…
Won't down load
Just use a memory card and a generic USB memory card reader. The cord system is a bad idea for any camera.
Nov 11, 2008 • Cameras
Carriage Jam Error display on the LCD!
SolutionStep one: Perform a power reset and connect the printer directly into the electrical outlet Remove all the paper loaded in the main input tray.Make sure that the product is turned off.
Disconnect the USB cable from the back of the product.
Disconnect the power cord from the product.
Disconnect the power cord from the electrical outlet and wait 10 seconds.
Reconnect the power cord directly into the electrical outlet and check for the following.
Make sure that the power cord used is the one provided with the product.
If a computer is connected to the product, make sure that the computer is connected to a grounded (three-prong) wall outlet.
Make sure that the power cord is firmly connected to both the product and the power supply.
Reconnect the power cord to the back of the product.
Press the power button ( ) to turn on the product.
Reconnect the USB cable to the back of the product.
If the issue is resolved, proceed to Step six: Print a self-test page.
If the issue continues, proceed to the next step.
for more information please go to below link>>
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458822&cc=us&lc=en&dlc=en
Thanks for using FixYa.
1helpful
2answers
Kodak easy share SV 811
I had the same problem. I use kodak easyshare software and load my pics on to that. Then put all the pics you want in the picture tray. Have your frame plugged into the computer with your usb cord. Then go up to File menu and drop down to "copy to". On my computer it is Folder "E" which is the drive the frame is connected to. Then pick from the Resize drop down menu " best for picture frame', then click copy. You will see the program loading all the pics to E drive. When done, unplug usb cord and you will see it loading on your pic frame. As easy as this is to do, I found it frustrating as well, but when it works, it is easy. Hope this helps
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
