Tab on the diverter valve is not broken off. So, now I am guessing the issue is in the Control Module which will require a service call and more expensive part.
Anything else I should try before I call for service?
washer is top load, gwl10--but I did not see that model as a choice for the Product.
If the tab is not broken take it out of the washer and remove debris from diverter valve
I’m happy to help further over the phone at https://www.6ya.com/expert/george_106a9535a98aec8a
SOURCE: Fisher & Paykel GWL10 US won't spin
If the machine still has water in it, the drain pump is jammed or there may be an obstrution in one of the hoses. It is most likely the drain pump. Switch off the machine at the wall and unplug it. Tilt machine against a wall and look underneath. On the right you will see the drain pump. It looks upside down. Unplug the wiring harness to the pump and remove pump by turning it clockwise while at the same time releasing the little white clip that holds the pump in place. Clean thoroughly and replace pump.
SOURCE: Fisher Paykel washing machine GWL10
Had the same problem with some other appliances. If you're not afraid to open the washer up, it's likely there's a fuse that has blown. If you can find a source for the EXACT same fuse (specs on the body of the fuse), replace it, or you may wish to risk a house fire by bridging the fuse with a piece of electronics solder.
SOURCE: Fisher & Paykel GWL10 question to Rescue Tech
First scoop out the water or run the pump in diagnostics mode and use a pitcher to bail out the water as it flows from the recirculation hose. Next, tip the machine back enough so that you can set something like a gallon paint can or other sturdy object under the front left corner of the machine to keep it propped up while you work under it. These machines are actually very lightweight. You do not remove the tub to service the diverter. There is a single 3/8" hex head bolt (which also is recessed with a phillips head) that secures the diverter to the base via a white nylon band. Remove the bolt, then remove the band, which is actually wrapped around the drain hose . Now remove the two wires, and the three hose clamps and all three hoses. Pop the valve out and take a close look at that diverter, if it is broken at the tab, this will be obvious.
The diverter is part number 426862P. You can order one here:
http://www.fisherpaykelparts.net/ecart/category.php?category_id=54
SOURCE: fisher and paykel gw509 not draining, pump is clear
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
SOURCE: Fisher Paykel GWL10 no power
Hi The issue is with the control board that has gone bad and
should be replaced to solve this issue. Unfortunately there is no such reset
button/fuse in your Top load washer. Hope this helps...please post back for
further assistance. Daniel
