Computers & Internet Logo
Posted on Jun 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
All of the icons from the screen disappeared!
The words:windows explorer has found an error was displayed and I couldn't take off my flash drive properly. The next thing i know all of the icons disappeared from the screen even the start menu button and the right click is not even working!!Please help!!
Threetech Solutions
Level 3:
  • Master 634 Answers
  • Posted on Jun 05, 2009
Threetech Solutions
Master
Level 3:
Answers
634
Questions
0
Helped
110169
Points
1539
Try to reboot your computer into safe mode.
To use a Safe Boot option, follow these steps:
  1. Restart your computer and start pressing the F8 key on your keyboard. On a computer that is configured for booting to multiple operating systems, you can press the F8 key when the Boot Menu appears.
  2. Select an option when the Windows Advanced Options menu appears, and then press ENTER.
  3. When the Boot menu appears again, and the words "Safe Mode" appear in blue at the bottom, select the installation that you want to start, and then press ENTER.
Then click start
click run
type in msconfig
uncheck everything under the startup tab except your antivirus
and reboot
1helpful
Operating system not found
hi goodner,
getting the error "operating system not found" means that the hard drive where the Operating System is installed (i.e. Windows XP, Windows Vista, Windows 7), Cannot be found by you BIOS upon the boot sequence.
When you turn the PC/Laptop, you normal see a screen that flashes flashes with screen that displays the ff:
Primary Master:
Primary Slave:
Secondary Master:
Secondary Slave:
The Primary master should have a value right next to it. If not, either the hard drive is faulty and needs replacement, cable is loose,
If you have a value to it and stil gets the same error the operating is corrupted and needs to be re-installed.
tip
Fix Windows 8 Error 10
The TIPS this article will help you get detailed diagnostic information and fix the error 10 in Windows 8 operating system.
Update Malfunctioning Drivers
Update the drivers for malfunctioning devices indicated with a yellow color exclamation mark.
gDz7TRY2sKy0361Sog6d_QRTmWz6S9-nl9X3yA0HIer5Haj_GQ5bV5l4qGjSNXSfX4ooWo_pbQ6262sUBB851TJtcW-Pgq_lfLjbzlCXBboCmW3twhWYyUDEwcIg" width="560px;" height="671px;" alt="Charms-Bar.png">
1. Press Windows Key + C.
2. The Charms Bar will be displayed.
3. Click the Settings icon.
4. Click Control Panel.
5. Click System and Security ' Administrative Tools.
6. Double click Computer Management.
7. After Computer Management dialog opens, expand the top root node, i.e. Computer Management (Local).
8. Expand System Tools node. Select Device Manager.
9. Yellow colored exclamation mark will be displayed to malfunctioning devices. Right click a device and select "Update driver software".
10. Follow the on-screen instructions.
Reset Internet Explorer Settings
Set the default browser settings.
6QpjEtDk8qJZs2mphJj-3-XktdOeYcnxtYFj11QQB9Xqb-p3l-thAWDgoVOpbENPhFwNwUnj-6qwJLTcXdFxvBp2jD4bP8Qxz5dblvcliY5Di5F8-Ju8sgiPg8xw" width="624px;" height="376px;" alt="Reset-Internet-Explorer-Settings.png">
1. Press Windows Key + X.
2. Select Command Prompt (Admin).
3. Type "inetcpl.cpl"
4. Press ENTER.
5. Internet Properties dialog will open.
6. Click the "Reset" button and confirm the action.
Change the Security Zone Settings
Go to the Security Zone settings and set appropriate levels for the Internet, Local Intranet, Trusted Sites and Restricted Sites zones.
AawqQhUftQ2Jr4EB1hN7dlsse5wSRe6YYQg1V7o0y6pPCnq1_hqiYQuJHHh7OcLoIV9ZopXEJfL3ieBFbaKIZhUP2I7N056B1fStHbuuudMooR6Vp9Jf0IigkTWg" width="423px;" height="542px;" alt="Internet-Options.png">
1. Open Internet Options dialog. (Refer Steps # 1-5 from Reset Internet Explorer Settings paragraph)
2. Click the Security tab.
3. Select "Internet" icon.
4. Move the "Security level for this zone" slidebar to Medium-High.
5. Click "Local Intranet" icon.
6. Set Medium-Low level for this zone as in the Step # 4.
7. Click Trusted Sites icon.
8. Set Medium level as in the Step # 4.
9. Click Restricted Sites zone and set High level for this zone as in the Step # 4.
10. Click Apply, and then OK.
Delete the Browsing History
Every time that you open Internet Explorer corrupt history is loaded. Delete the browser history to fix Windows 8 error 10.
XDtvYecmugRcsb198KaB0YszDRSi1mGcxY-wpowd_jfyYmqawXrtuuTFZH54IAsNi0v4UUW-2gJD_U9ytRKvDgAemkWIOA25IhmJckjLYMKwZF79ooH8bblZQfOw" width="624px;" height="332px;" alt="Delete-Browsing-History.png">
1. Open Internet Explorer.
2. Press the Alt key of your menu bar.
3. Select Tools ' Delete browsing history.
4. In the new dialog check-up all the checkboxes displayed.
5. Click the Delete button to start cleaning the Internet history.
Disable the Smooth Scrolling
Smooth scrolling feature may not work properly due to graphics issues. Disable the smooth scrolling feature to prevent this problem.
2. Click the Advanced tab.
3. Scroll down the scrollbar. Under Browsing category uncheck the "Use smooth scrolling" checkbox.
4. Click Apply ' OK.
5. Exit and re-open the Internet Explorer.
Turn Off Hardware Acceleration
Many applications use the hardware acceleration feature. Disable the hardware acceleration and check whether it helps.
qBTFDPo49_raes7y1knOMykZeW33CJRJ7QDmYryXT2oBZ3ZyVLy4pZPxgWA5L2yDsPwSbFizWYppPUn2MNFY-OLGuLnWimun1HJmmBjRP7s3RnzyBFnkKyevZadA" width="624px;" height="435px;" alt="Display-Settings.png">
2. Select Search option.
3. Type "desk.cpl" in the Search Box.
4. Click the Apps icon and open it from the Search Results.
5. Screen Resolution dialog will open. Click the "Advanced settings" link.
6. In the subsequent dialog click the Troubleshoot tab. If that tab does not exist it means your graphics card does not support the hardware acceleration feature.
7. Set Hardware Acceleration= None
8. Click OK ' OK.
Reregister Problematic DLL
Reregister the system file named rasppoe.sys using Command Prompt.
k_C1fljiI30RqbQr0RcDaLI67Bnrxyc-t2BAynOldOVABPjSCHobXaDc9h4wPhKwG41xuthC1yEtgpkeE1mYd4z5GscwbRq8KvN_bm07yrrMJt8RTD8v87VsgLsw" width="624px;" height="316px;" alt="Register-DLLs.png">
1. Press Windows Key.
2. Type "CMD" in the Search Box.
3. Click the Apps icon.
4. Right click the "Command Prompt" icon in the Search Results page.
5. Click the "Run as administrator" icon at the bottom of the page.
6. Type the following command:
Regsvr32 rasppoe.sys
7. Press the ENTER key.
Rename Problematic DLL
If there is any problem with the rasppoe.sys it will be resolved after renaming the file.
1. Double click Computer desktop icon.2
2. Open the following location:
C:\Windows\System32\Drivers
3. Rename "rasppoe.sys" as "rasppoe.sys.old"
4. Restart your computer.
Turn Off the Software Rendering
If the software rendering feature is not supported, simply disable it.
1. Open Internet Explorer dialog box. (Refer Steps # 1-5 from Reset Internet Explorer Settings paragraph)
3. Uncheck the checkbox named "Use software rendering instead of GPU rendering" under "Accelerated Graphics" category.
Change NVIDIA Graphics Settings
Go to the NVIDIA Graphics Settings and uncheck the Stereoscopia 3D setting.
Reinstall Flash, Java & Silverlight
Uninstall and reinstall these three programs to check whether program files corruption was an issue or not.
ueHytD4giGWOXrR_3IWKFfhwbQ9jzLmwUo4vkrzaGnQ4codvWpaKLAD2mWNh7vMHYdPxG-1cgfa91Bj_oMXCyeJ65-x4gMobvJBCNBR6fFp7rDxkurxoAbK5nahQ" width="624px;" height="435px;" alt="Programs-and-Features.png">
2. The Start Screen will open.
3. In the Start Screen type "Uninstall a program" in the Search Box.
4. Click the Settings icon.
5. Open it from the Search Results.
6. Right click a program name and select Uninstall option. Uninstall the Flash, Java and Microsoft Silverlight.
7. Download the above programs from the Internet.
Change the Environmental Settings
Change the values of Environmental Settings in order to fix Windows 8 error 10.
8yve5KFc4UjrHg0s4dJHlHctnOeiBs9cI9FSVHoa0nsfecop4N8kbc2ccl8bOHdcsetF6ZIhLA3L_WGSsmOnR6gM4rolUg8o5-YeAfTEMMSXhOBjT8nWUqBR0XpQ" width="397px;" height="439px;" alt="Environment-Settings.png">
1. Right click Computer desktop icon.
2. Select Properties from the context menu.
3. Click "Advanced system settings" link.
4. System Properties dialog will open.
5. Click the Advanced tab.
6. Click Environment Variables button.
7. Under "User variables for " category two temporary folders will be displayed.
8. Select the "TEMP" folder.
9. Click the Edit button.
10. Specify Variable Value: "C:\Tmp" (without quotes).
11. Click OK ' OK ' OK.
Fix Issues in Registry
Often errors in Windows registry result in such problems. It is wise to keep Registry cleaned from corrupted entries. To fix Windows 8 registry, use the Intel Software Partner Reginout System Utilities here: RegInOut System Utilities
Hai..
if you really are asking for the parts of MS word 2003,i bet this should help and really there are more than 4 parts
1. The Title bar gives the name of the document and the program being used
2. On the right side of the Title bar are three buttons.
a. The Minimize button makes the window disappear from the screen without closing
the program. You can bring the window back by clicking on its button on the Task
bar at the bottom of the screen.
b. The Reduce/Maximize button makes the window smaller or takes it back to full size.
c. The Close button closes the document or program.
3. The Menu bar offers dropdown menus for things you do in Microsoft Word.
4. The Toolbars display icons that perform specific tasks when clicked. Often the toolbar icon performs the task without offering any options.
5. The Rulers display the tabs, indents, margins and give the user a visual guide for alignment.
a. Tabs are set on the ruler by clicking the spot on the ruler where you want to the tab to
start. Different Tab settings can be used to align text, decimals and indents.
b. Indents and margins can be set with the handles.
6. The Document display window is where the current document is visible.
7. The Scroll bars allow the user to move up and down the document in the window.
8. The Status bar shows the location of the cursor, number of pages and includes advanced toolbar options.
9. The Task bar displays buttons for Open programs or documents.
F drive error Ox80070052
Reboot. Open Windows Explorer (Win key + E). Insert drive. Does F or any other drive become available?
1helpful
An error occcurred during the installtion of my HP 7280 photosmart printer. The parameter in incorrect.
Microsoft Windows 2000 and XP require files named printupg.inf and printupg.PNF to be found in the Windows .inf folder. If these files are missing or damaged, no printer can be installed and the error of incorrect parameter will come, and the existing files need to be removed if present, and a fresh copy of printupg.inf restored from the Windows backup archive. Kindly Do the following steps:--------
  • Double-click My Computer on the first screen or in Start menu.
  • On the Menu bar, click Tools , then Folder Options
  • Click the View tab.
  • Under Hidden Files And Folders, select Show hidden files and folders
  • Deselect Hide extensions for known file types and Hide protected operating system files .
  • After the above steps, you will be sure that the Computer is showing all files. After it >..............
  • Close the other applications. Double-click the hard drive icon that Windows is installed in, the name usually ends with C: .
  • Double-click the Windows or WINNT folder icon.
  • Double-click the .inf folder icon
  • On the Menu bar, click View , then Details .
  • Click the word Name above the list of folder and file icons until the list is in alphabetical order.
  • Scroll down the list to the section where files starting with the word print are located.
  • If files are found named printupg.inf or printupg.PNF , rename them using the following procedure:----
  1. Right-click on one of the files, then click Rename
  2. Click at the right edge of the file name to remove the highlight from the name.
  3. Press the Backspace key on the keyboard three times to remove the inf or PNF letters
  4. Type the reverse of the three letters, then press the Enter key on the keyboard. For example, inf would be replaced with fni, and PNF would be replaced by FNP.
  5. If the other file is present, Repeat Steps as through in step 4.
  • Insert a new copy of printupg.inf into the inf folder using the following procedure:
  1. Determine where the correct i386 folder is by double-clicking My Computer on the first screen or in the Start menu, then double-clicking the icon that ends with C: If the i386 folder is not displayed, click the Up or Back arrow at the top of the window, then try any other icons that look exactly like the one already tried, one at a time. If the i386 folder is still not found, insert the Windows or computer manufacturer recovery CD-ROM disc and double-click each icon that looks like a CD-ROM disc one at a time.
  2. Make a note of the path where the folder is found, including the drive letter at the end of the icon name. If folder icons were double-clicked during the search, do not use the i386 folder found after double-clicking the Driver Cache folder. For example, if the i386 folder was found on the recovery CD-ROM disc in drive G: , in folder Archive, the path would beG:\Archive\i386. If the folder was found in the computer's hard drive, the path will probably be C:\i386 . If it was found on the Windows CD-ROM disc inserted in the drive icon ending in M: , the path would be M:\i386
  3. Click Start , then Run
  4. In the Run box, type CMD , then click OK
  5. At the blinking cursor in the black box, type the following statement, where PATH is the actual path determined in step a above and _ is the underscore key, which requires holding the Shift key while pressing the Dash key: EXPAND PATH\printupg.in_ C:\XXX\inf\printupg.inf .
  6. The text that Windows displays in the black box will now indicate if the file was found and expanded or not. If the text includes an error message, type the statement above again at the blinking cursor, checking for accuracy. Ensure that all backslashes and the single blank spacebar key after the underscore (Shift+Dash) are included, and that a full colon is typed after each drive letter.
  7. If another error is displayed, verify that the PATH being typed is correct by referring to step a above, then type the statement again
After the file has been successfully expanded, close the black box. The missing printupg.PNF file will be created by Windows when it is needed.
  • Uninstall and reinstall the printer software by using the procedure recommended in the documentation that came with the printer.
Thank you, Have a nice day.
Internet Explorer icons, home page, and all documents disappeared
Adobe conned you into using it as your default browser. You want to change back to IE# as your default web browser right?
Outlook Free/Busy error
Hope this solves it for you! Here's the official word from Microsoft:
If you receive one or more of these error messages, you may experience performance issues until Outlook finishes the reconciliation process for the .ost file or for the .pst file. The following gear icon is displayed in the status bar while Outlook checks the data file in the background: Collapse this imageExpand this imageol2007gearicon.jpg When this icon disappears, the .pst file or the .ost file is reconciled. If you exit Outlook while the gear icon is present, reconciliation must restart the next time that you run Outlook. We recommend that you leave Outlook running until the gear icon disappears before you exit Outlook.
An incorrectly shut down .ost file or .pst file may occur for one of the following reasons:
  • Antivirus scanning of the file
  • Forced Microsoft Windows shutdown before the Outlook.exe process shuts down completely
  • Outlook add-ins
If you see this issue frequently, and you have to exit Outlook shortly before you shut down your computer, it may be better to shut down Windows while Outlook is still running. We recommend that you do this instead of exiting Outlook and then shutting down Windows shortly after that.
Cannot access any programs on Toshiba Satellite A135-S4517
Either a tune up, or it has a faulty hard drive. If you can manage to get to My Computer, right click your C: drive, select Properties, go to the Tools tab and click Check For Errors. Check all the options, and start it. It will tell you that the tests can only proceed when you reboot. Check it in order to do so and reboot.
Good luck.
4helpful
6answers
1helpful
"My Handheld PC" and "Recycle Bin" icons disappeared
This problem is experienced after following performance suggestions found in third-party documentation, on web sites, or in newsgroups. These suggestions instruct users to remove all folders from the desktop of Handheld PC Pro device in order to speed screen-repaint rates. Applying these same steps on a Handheld PC 2000 device causes all desktop icons to disappear. Microsoft has documented this issue (in Q289674): http://support.microsoft.com/support/kb/articles/Q289/6/74.ASP To restore the My Handheld PC and Recycle Bin icons on the device, follow these steps: 1. Tap Start, tap Programs, and then tap Windows Explorer. 2. Tap the My Documents folder, tap Send To on the File menu, and then tap Desktop as Shortcut. 3. "Soft" reset the MobilePro. The My Handheld PC and Recycle Bin icons should return to the desktop. Note that you must have at least one folder or shortcut on the desktop in addition to the My Handheld PC and Recycle Bin icons, or else the problem will recur.
Grand Canyon Tech
Grand Canyon Tech
