HOW DO I TURN OFF DO NOT DISTURB
SOURCE: setting the time on the panasonic KX-T7630
This is a PBX system, correct? If so, the fastest way would be through the PBX control computer. If you have a Panasonic TAW series PBX, I really like the AbleComm websites, search for your model PBX there.
SOURCE: Change Time
Press 'Prog' then press star key twice, then enter '1234', then enter '000', will get you to Date & Time Set, then press 'enter' button (bottom right hand corner of phone), this will then allow you to change the date and time accordingly.
Hope all goes well
Tess, Australia
SOURCE: kx-t7630 product spport
This is how I did it:
1. Press the 'Program' button
2. Then dial ** (star, star)
3. Enter the password (usually 1234)
4. Press 'Next' until you get to 'Ext Name'
5. Press 'Enter'
6. You will need to know the Extension Number of you phone, when you find out enter it (eg: 104 or whatever yours is)
7. Press 'Clear' to get rid of the old name then start entering the new name via the number keys. Note: If you keep cycling through the letter on each number you can get to lowercase or uppercase letters.
8. Press 'Enter' then you are all done... pick and hang up the handset.
SOURCE: How do I change the language on my panasonic kx-t7630
Press the left button under the display (PROG in English) dial 021 STORE (4th soft key).
Now the buttons say PROG :-)
Carl
SOURCE: how do i change the time on the phone?
Press Prog or Pause, **, and then enter your system password (default is 1234).
Press 000, Press Enter, enter the YEAR
Press select for Month
Press right arrow, enter date (MM-DD)
Press Enter, Press Next, Enter Hour (01 to 12)
Enter minute (00 to 59 seconds), select AM or PM, press enter, and then press hold.
Exit until you are back at the main screen and you're done!
