JVC GR-D250 Mini DV Digital Camcorder Logo
A
Anonymous Posted on Jan 26, 2014
Safe mode error 03 - JVC GR-D250 Mini DV Digital Camcorder
My camcorder is stuck in safe mode
I need to know more details about your problem, error code follows numeric code. Such as 01, 02, 03 etc. you need to consult an expert. Don't force the mechanism for it will cost you more to repair.
Computer only starts up in safe mode.
Your best bet is to remove all of the PCI cards from the slots - not for the faint of heart, but worth a shot. POWER OFF THE COMPUTER, then open up the computer and look for any cards that are in the white PCI slots on the motherboard - there will be one screw to remove per card and then pull straight up to remove the board. Once all are removed, turn on the computer. If it boots properly, shutdown again then add one card at a time until you find the faulty one. Good luck!
2helpful
4answers
Have a jvc camcorder turn on and it says safe mode remove battery
Forget the battery, the mini dv carrage assy can get out of sync and initiate the safe mode, if you noticed a problem loading the tape or have heard a gear skip sound thats the problem. The best you can do with those camcorders is keep the tape in the camcorder!!!!! That will prevent the problem and insure many good years of recording.
Sorry,
Tim.
2answers
I'm getting an E04 ( error) when I try to record or play
Here is some information regarding the E04 error message from http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/:
"JVC notes that you are also given a malfunction code when the unit is placed into safeguard. If it displays code 01, 02, or 06 you should remove
the battery and powersupply and wait for a while. Code 03 and 04 indicate that you should eject and reinsert the tape.
If neither of these solutions work, your only alternative is to bring it to a shop or send it to JVC for diagnosis or repair. Unfortunately, there is no other way to clear the condition."
This doesn't seem uncommon, and indicates a bad tape is loaded, or unfortunately, that the camcorder requires servicing.
2helpful
3answers
KONICA 7020 GIVES ERROR MESSAGE F-35-1O WHAT IS WRONG
hi
error f 35 is fixing error,try to reset on 25 mode
DVD Recorder/VCR 80 GB HDD
Tyr using -r dvds ,,,,,that might resolve your problems
2helpful
4answers
Unit in safeguard mode
You mix te info with Write protected tapes.
Safe guard mode is caused by the motor that takes the tape out of it's case, through the mechanics and past the video head.
If for some reason the electronics detect that it's been done by too much force, the safe guard issue promts.
Top JVC Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
