20 Most Recent Toshiba E-Studio 3511 Color Copier Questions & Answers
File storage error when scanning..comes up 0kb
called service....had to reload programs
11/11/2021 6:51:34 PM • Toshiba E-Studio... • Answered on Nov 11, 2021
I can't print in color
The reason you are not able to print is color may be because the administrator has set the printing not to allow color printing
You will need to check the settings in the print driver to see what has been allowed or not allowed
11/11/2021 5:39:12 PM • Toshiba E-Studio... • Answered on Nov 11, 2021
2answers
I can buy copier sencondhand
http://www.craigslist.org
10/31/2019 3:51:19 PM • Toshiba E-Studio... • Answered on Oct 31, 2019
Error code "CA10"
Hi how are you this is jack .....([email protected]).. my personal ID.
Laser optical unit related service call
[CA10] Polygonal motor abnormality
Is the polygonal motor rotating?
NO 1. Check if the connector CN352 on the LGC board is disconnected.
2. Check if the harness is open-circuited or the connector pin is disconnected.
3. Check if the conductor pattern on the LGC board is short- or open-circuited.
4. Replace the laser optical unit.
5. Replace the LGC board.
YES
Is the printed image distorted?
YES 1. Check if the connector CN352 on the LGC board is almost disconnected.
2. Check if the harness is almost open-circuited or the connector pin is almost
disconnected.
4. Check if the laser unit cooling fan is stopped.
5. Check if the suction area of laser unit cooling fan is plugged up.
6. Replace the laser optical unit.
7. Replace the LGC board.
Thanks
Best Regards,
12/13/2018 4:23:44 AM • Toshiba E-Studio... • Answered on Dec 13, 2018
Job Reservation Full
It means that the number of reserved jobs has exceeded 100. You can either wait for the reserved jobs to be completed, or check the jobs and delete the reserved jobs
7/28/2018 7:27:53 AM • Toshiba E-Studio... • Answered on Jul 28, 2018
Error code CEEO
From the Service Handbook:
- Transfer belt marker detection abnormality (normal operation):
- The home position of the transfer belt cannot be detected.
Check if the sensors in the transfer belt are clean, they may be dirty. Check if they are working normally. Also, better if you install bright silver sticker or tape on the reflectors inside the belt.I have experienced that Those reflector get dusty or worn out and sensor can't check them and error occurs.
Open up your Transfer ***'y Unit , Take out the Transfer Belt see if your Silver Marking Stickers behind the transfer belt missing or very dirty.Check the Silver marking censor inside the Tranfer ***'y Unit..it will solved the problem.
Hope helped.
2/25/2018 8:52:45 PM • Toshiba E-Studio... • Answered on Feb 25, 2018
2answers
My mac 10.6 OS does not have any drivers but
You will not be able to, because the primary drivers for the Toshiba E-Studio 3511 Color Copier, are too old for the Mac OS X 10.6 Snow Leopard printer.
As you already may be experiencing, the range of use for your Toshiba E-Studio 3511 may work with various generic drivers and will not improve due to the Toshiba printer's incompatibility with Mac OS X 10.4 - 10.6.
You will in fact, always have a very limited to basic use of this Toshiba Color copier in Snow Leopard, because the driver support stopped at Mac OS X 10.3 Panther and there are not even any drivers for Mac OS X 10.4 Tiger for this Toshiba printer.
Printer drivers for
Toshiba E-Studio Color Copier:
* Windows98/Me/2000/XP/2003 Server (only 32Bit), * * Windows NT4.0,
* Macintosh 9.X, X ver10.1/10.2/10.3
* Unix (HP-UX 10.20/11.X, Sun Solaris 2.6,2.7,7.8,8,IBM AIX, Linux)
Link to Technical Specs page:
Toshiba E-Studio 3511 Color Copier Technical Specifications
If you want review compatible printers for Mac OS X 10.6 Snow Leopard, here is the Apple link for this list:
Mac OS X v10.6: Printer and scanner software
Hope this helps!
Regards,
-Mactechtrainer
Sr. Mac Support Specialist
12/7/2017 6:41:24 AM • Toshiba E-Studio... • Answered on Dec 07, 2017
How can I reset a Toshiba E3511 copier back to factory defaults?
What is DA
9/18/2017 10:13:02 AM • Toshiba E-Studio... • Answered on Sep 18, 2017
MY TOSHIBA E-STUDIO 452 HAS A MESSAGE OF INSTALL NEW TONER AND I HAVE INSTALL A NEW TONER ALREADY
Step 1:- Switch off the machine Step 2:- Press 0 & 5 simultaneously Step 3:- Switch on machine. Step 4:- The display shows test mode. Step 5:- enter code 200 Step 6:- the machine starts automatic adjustement of auto toner sensor , and when the display shows adjust mode then press enter on the display. Step 7:- Now switch off & on and check the problem should be resolved. If problem continues then maybe, changing your developer may solve the issue.
7/31/2017 7:43:44 AM • Toshiba E-Studio... • Answered on Jul 31, 2017
Como instalar el escaner del una toshiba estudio
buenas noches quiero sabe como scanear en la multifuncuional toshiba 2330c y hacia que carpeta direcciona los documentos gracias
1/5/2017 12:02:12 AM • Toshiba E-Studio... • Answered on Jan 05, 2017
My problam CEAO CODE INDICATING
Hello dear: i have a copier machine Toshiba e studio 3511 , and i thing the cdd is fell, how i would do to make work , please can you healh me with themy name is Edgar
6/18/2016 9:54:17 AM • Toshiba E-Studio... • Answered on Jun 18, 2016
I have got problem with copier toshiba e-2830 error code CA20
try rest the copier by switch on the copier while pressing '0&8" enter 690 press start button enter 2 press enter key on touch screen, wait till you see 'Reboot the machine: It is communication err.
12/4/2015 5:15:15 AM • Toshiba E-Studio... • Answered on Dec 04, 2015
My Toshiba estudip 3500 is not printing no color on transfer belt during calibration
U might need to check your laser unit...
7/30/2015 2:49:53 PM • Toshiba E-Studio... • Answered on Jul 30, 2015
Toshiba E-Studio 3511 Color Copier Logo
290 questions posted
Top Toshiba Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Office Equipment & Supplies
Most Popular Question
job reservation full
  • Office Equipment & Supplies
