Fujitsu Siemens ESPRIMO MOBILE V5535 Laptop Universal AC Adapter 18-20v (AC22VPNVK5EA7) Logo
Henry Mack Posted on Jan 25, 2014
Loss of Wi-fi
I have two laptops and a tablet since a change of ISP I have lost wi-fi only on the Esprimo
Alice Graves
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 25, 2014
Alice Graves
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
78
Points
Have a Inspiron Mini 10 Model P19S belonged to my sons girlfriend .. they broke up and she told him to keep it..when i turn it on it show password, but she refuses to give me the password. I tried the F8 to return to safe mode. This don't work. I would like to access the computer to use it, but seems nothing is working. I don't have money to take it to a computer expert. Can you give me any assistance please. I would appreciate any help.
I can't get it to go on my wi-fi. Help!
1st pass, go into the settings (the gear icon) amd make sure that wi-fi is turned on. I don't recall mine doing that but that was a couple of tablets (several years) ago.
2nd pass, if the wi-fi is on, make sure it is seeing your wi-fi hub (router).
3rd pass, if the wi-fi is on and you can log into the router with another machine (like a laptop or smart phone) then it's time to get it replaced and hope the warranty is still in effect. If the warranty has expired, go onto ebay or Amazon and get a real tablet. iRulu was my first tablet and I consider it to have been a piece of junk. Definitely not worth even the small price I paid for it.
Unable to get internet
You can separate the troubleshooting into parts. Go to a place having a wi-fi internet hot-spot, like Starbucks or Gloria Jeans'. Assuming you are in the USA:
http://www.wififreespot.com/
Get a coffee and turn your tablet wi-fi on. From
http://www.manualslib.com/manual/742236/Rca-Rct6272w23.html?page=11#manual
1. Go to Settings > WIRELESS & NETWORKS > Wi-Fi, and slide the Wi-Fi switch to the ON position.
2. The device will scan Wi-Fi networks automatically and display the available names.
• If the device finds a network that you connected to previously, it will connect to it automatically.
3. Tap a network name to connect to it. Tap 'Agree to conditions' if necessary.
You should then be able to go to a webpage. Once you get this bit working, you can turn to your home internet.
You need of course an account with an ISP, who will probably supply you with a gateway (modem/router). If you only have a modem (connection box to the ISP) that does not have a wi-fi capability, you will need to get a router (wi-fi broadcaster). These can be quite small and neat.
http://phandroid.s3.amazonaws.com/wp-content/uploads/2015/10/OnHub-by-ASUS-Screen-Shot-2015-10-27-at-5.29.02-PM.png
For assistance on this contact your ISP tech help line, since some of the advice is peculiar to the equipment they use.
Connect the router (if you needed to get one) to the modem with an ethernet cable
http://cdn2.pcadvisor.co.uk/cmsdata/features/3502678/ethernet-cable.jpg
and follow the setup instructions that came with it. Then do the same as in the cafe wi-fi hot spot. It should work.
2answers
How do I set password on Wi-Fi orca android tablet
Answer Line: Change your Wi-Fi password on various ...
www.pcworld.com/.../change-your-wi-fi-password-on-various-...
PC WorldFeb 11, 2013 - But Wi-Fi passwords, like every other kind, need to be changed every so often. Here's how to ... Android. You can't simply change the password here; you'll have to delete the network from your phone or tablet and recreate it.Missing: orca
How to Connect Your Android Tablet to a Wi-Fi Network ...
www.dummies.com/.../how-to-connect-your-android-tablet-to-a-wifi-net...
After you've activated the Android tablet's Wi-Fi radio, you can connect to an ... ... Be careful when connecting to a non-password-protected network. It's possible ...Missing: orca
How do i change my wifi password [Solved] - WiFi - Cell Phone ...
1helpful
Cant get wi fi signal.
Solution 1.Check wireless connection.
The first step of diagnosis have to any other device connected to the same network, ensure the wireless connection is working fine, or verify the settings of your wireless router to correct it.
2.Check your Keep Wi-Fi on during sleep Settings.
Owing to Wi-Fi sleep policy your Wi-Fi connection may be going to get disconnected every now and then.
Tweak this policy to keep your Wi-Fi connection awake.
[Settings] >>[Wi-Fi]>>[Advanced]>> Check [Always] to keep the Wi-Fi on during sleep.
Save changes and exit all the screens. Your Wi-Fi will never get disconnected again due to this policy.
3.Check signal strength of wireless connection.
The performance of a wireless network connection depends in part on signal strength.
You have to connect the Wireless network where the signal strength is strong.
Check Wireless network signal strength icons in notification bar.
4.Try to turn off/on Wi-Fi on the device.
First to turn off Wi-Fi, [Settings]>>[Wi-Fi] >>[turn Wi-Fi to off].
And then to turn on Wi-Fi, [Settings]>>[Wi-Fi]>>[turn Wi-Fi to on].
5.Try to forget network on the device.
Forgetting wireless networks allow your tablet/phone to reset some settings.
[Settings]>>[Wi-Fi]>>Press & hold your[Net Work Name(SSID)]for 2 seconds.
>>Select[Forget Network]>>Re-Connect your wireless networks if it's disconnected.
6.Try to reboot your device.
7.Make sure your firmware is up-to-date.
>>Select[Settings]>>[About tablet]>>[System Firmware Update]>>[Check Update].
8.Try to reset your device.
Note: once RESET was performed, all data, apps, settings and personal information will be deleted after initialization.
Third-party programs might be the major probability of Tablet/Phone instable, suggested to have a full reset for the device if the situation persists.
[Settings]>>[Backup&reset]>>[Factory data reset]
9.Try to other wireless connections.
If steps above were not able to solve internet connection problem still, please try other wireless connections if available, otherwise contact your networking provider to technical support.
I have a subscription to netflix at home lhave wi fi at work how do I change my settings on samsung tab with affecting my home account
As long as you have the Netflix icon on your tablet you should be able to sign in without changing anything. It doesn't matter what wi-fi that you're using as long as you work wi-fi doesn't block access to Netflix.
Wi fi not working
Apple products for cell phone and tablet. if yes turn off wi fi on these devices and try reactivating Wi fi. Try changing encryption to WPA rather than WPA2 on wi fi router.had similar problem I solved with apple iphone 5 for a friend I helped.
My new zte v9 wont connect to the Internet
you can access the Internet through the mobile network or via Wi-Fi.Your mobile network settings are pre-configured by your serviceprovider and there is no need to change any settings. Wi-Fi Wi-Fi provides wireless Internet access over distances of up to 100meters.1. Tap Home > Settings > Wireless & networks .2. Select the Wi-Fi check box to turn Wi-Fi on
Lost wi-fi facility
Hi, Well you have formatted the system, so you need to install the Wi-Fi driver in order to access the Wi-Fi. ou must be having the driver CD, If you dot have just download the wi-fi driver from internet and install it on your Laptop and re-start the laptop and you will be able to access the Wi-Fi again.
Regards, polysandy
Top Fujitsu Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
