20 Most Recent
ZTE V9 Smartpad Android Internet Tablet Questions & Answers
ZTE K88 Trek 2 8" tablet HD. I need help charging my K88 tablet.
Question edited for a lot more clarity and spelling 'charging', no 'e'.
Question moved from Cars and Trucks
Make sure the wall plug socket is known to work.
Make sure the charger is known to work on another tablet or phone.
Try a different lead.
Try a factory reset, press and hold volume up and power buttons.
Send it in for warranty repair.
Zte v9c FTM after solution
See if you can remove the battery out for 1 minute. Put it back and try to turn on your phone. See if it will boot.
If that does not work, please remove the battery out and put it back in right away. Then press and HOLD Volume Down and Power buttons at the same time for 10 seconds. See if it will turn on and work normally or you will see the Recovery Menu.
Forgot password
You can't login into ?????. A little more information would help.
FTM shows up on screen
No bluetooth can i get an app
Blue tooth capabilities requires hardware chip and programming.
If your tablet does not have built in blue tooth, then the answer would be a negative. If tablet is blue tooth capable, the blue tooth device must be capable to mate to tablet blue tooth version technology.
Hi My zte F102 is on ftm mode what should i do
Try removing the battery to turn the device off. Replace the battery and then turn the phone back on and you should be out of FTM.
FTM, is usually entered by holding a button combination down when turning the phone on. Sounds like you accidentally figured out that combo when you turned it on. It could be as simple as holding the power button while turning on.
Can't access internet
Did you try uninstalling the app to see if that was causing a problem? If that doesn't work, is it your network that isn't working or just your device?
Tablet won't turn on
I got a hannspad tablet for Christmas and it worked for awhile and now it wont turn on???
