20 Most Recent Fujitsu Siemens ESPRIMO MOBILE V5535 Laptop Universal AC Adapter 18-20v (AC22VPNVK5EA7) Questions & Answers
Use a temporary external USB mouse, Click Start button from your laptop. Type "mouse" in Search Program & Files, click mouse under control panel. click Hardware tab,click properties, click change settings, click driver tab, check if the device is enable or click update diver or rollback driver if necessary.
Fujitsu Siemens... | Answered on Aug 25, 2014
The power switch is a momentary switch.. Its just closing a circuit to tell the computer to turn on.. If you "hotwired" the switch to constant then it will never boot because it has a constant connection instead of the momentary it needs as its boot signal.
Fujitsu Siemens... | Answered on May 06, 2014
Have a Inspiron Mini 10 Model P19S belonged to my sons girlfriend .. they broke up and she told him to keep it..when i turn it on it show password, but she refuses to give me the password. I tried the F8 to return to safe mode. This don't work. I would like to access the computer to use it, but seems nothing is working. I don't have money to take it to a computer expert. Can you give me any assistance please. I would appreciate any help.
Fujitsu Siemens... | Answered on Jan 25, 2014
Go to Start > Control Panel> System and Security> Power Option> Change Plan Settings> Right down on the bottom you will have Adjust Plan Brightness (if you are running windows 7). For windows 8 should be under power options as well. Good Luck!
Fujitsu Siemens... | Answered on Jan 13, 2014
http://download.cnet.com/realtek-rtl8139-family-pci/3000-2112_4-91313.html
http://download.cnet.com/wireless-atheros-ar5b91-7/3000-2112_4-202570.html
http://download.cnet.com/Realtek-RTL8139-Family-PCI-Fast-Ethernet-NIC/3000-2112_4-91313.html
if these packages are not the right
http://download.cnet.com/2000-20_4.html
On the home page you should see a search tab just type in what you are looking for
tick in the box for windows software or all software box
IE: Motherboard name wireless or Ethernet driver
you might have to try a few times to get it right
hope this helps
Fujitsu Siemens... | Answered on Nov 11, 2012
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures.
Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees.
Rotating the computer screen allows for more display options.
For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display.
Windows XP/Vista Monitor Orientation
Minimize any windows or programs to the taskbar. Click the desktop.
Press "CTRL" + "ALT" at the same time.
Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees.
The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation.
Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation.
Windows 7 Monitor Orientation
Click the Start menu at the lower-left hand part of the screen, and open the Control Panel.
Select "Display," then click "Change display settings" from the left column.
When using multiple monitors, select the monitor that you would like to rotate.
Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference.
Click "Apply" in the Display Settings window.
Click "OK" to finish.
Hope this helps
Fujitsu Siemens... | Answered on Oct 24, 2012
Click "Start" and then "Control Panel."
Click "Appearance and Personalization."
Click the "Adjust screen resolution" link under the Display heading.
Click the "Advanced settings" link.
Click the "Adapter" tab. You will see the properties of your graphics card.
hope this helps
Fujitsu Siemens... | Answered on Oct 16, 2012
press F1 and FN at the same time
Fujitsu Siemens... | Answered on Sep 21, 2012
you will need to open up your network connections
click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red X or a yellow exclamation or question mark ! ?
you will need to update or install the driver or it could be firewalled
click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question mark? right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc or you might download one if you dont have on a disk
Make sure you Ethernet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to
press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals
look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabled
click start type cmd press enter you will be in DOS mode
type in ipconfig press enter
you will see all of your internet connection details
or type in your default gateway adress into your internet search should read something like 10.0.0.138 to get an inertnet connection
wireless network troubleshooting tips
hope this helps
Fujitsu Siemens... | Answered on Aug 12, 2012
http://download.cnet.com/sis-vga-driver-3/3000-2108_4-164001.html
http://download.cnet.com/sis-sis650-sis740-family/3000-2108_4-10163382.html
if these drivers are not right
on the home page you should see a search tab just type in what you are looking for
eg:mtherboard name ethernet driver
hope it helps
Fujitsu Siemens... | Answered on Jul 17, 2012
the charging port in the laptop is either loose or has a bad soilder on it.
Fujitsu Siemens... | Answered on Apr 22, 2012
try going to device manager and try to see there if your sound card is in the list, if its not then your sound card is defective. by the way, did you install the right driver for your sound card. virtual sound drive wont work if you have the wrong sound card driver and a defective sound card.thanks.
Fujitsu Siemens... | Answered on Jul 11, 2011
Fujitsu Siemens ESPRIMO MOBILE V5535 Laptop Universal AC Adapter 18-20v (AC22VPNVK5EA7) Logo
38 questions posted
Top Fujitsu Computers & Internet Experts
Ekse
Erni Mallari
Erni Mallari
Carlo Barzo
Carlo Barzo
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Fujitsu Computers & Internet
Most Popular Question
esprimo ethernet driver
  • Computers & Internet
