Jams on multiple copies and paper turns pink
SOURCE: konica minolta 2430 DL paper jam
Place a few papers in the tray.
Open up the top, pull out the main (green handle) thingy.
In the very bottom you will see a bar with a single large round rubber wheel in the middle, and white gears on both ends of the bar.
Manually turn the right side gear toward you.
As you do this, you will see the paper lift up and as the rubber wheel turns you will see that it has a notch on the bottom side.
Turn the gear, and watch the rubber wheel until the notch on the rubber wheel is facing up and away from you (and the paper is fully engaged).
Then put the green-handle thingy back in, close the printer, and it should work.
Apparently this resets something. I have done it a number of times - usually after a paper jam.
SOURCE: konica minolta 1350w status display comes on at start up
Open c:\windows\system32
find a file called MSTMON_Q.EXE
right click and rename the file to anything with a file extension .exe, I named it MSTMON.EXE
Create a shortcut to this new file in case you need it in the future and put the shortcut on your desktop
also, write the original name of the file down or put it on notepad, in case you want to change it back.
restart windows
SOURCE: konica minolta pagepro 1400w paper jam
have you tear the paper when removing? there is a small paper left still inside the paper path. open the back side and the top part and check for small paper. I hope that will solve your problem and if think the problem still there the problem is one of the paper sensor actuator is broken or out of place.
SOURCE: The ADF Konica Minolta causes paper jamp or may bend 1 corner of
hi, clean the front roller take up ADF with alcohol and the little glass
