Print unable 1A indicates condensation forming inside the machine. If the condensate drops on to the main circuit board (positioned just under a metal bar that acts as a moisture condenser) you have a terminal fault. If your machine is still reporting a 1A error after two weeks in relatively dry conditions, it is probably all over bar the burial ceremony.
I have a Brother HL-3040cn printer, led display says "unable to print 1A" how do i clear this? It also says to turn the power off and open the top cover wait 30 minutes then turn it back on. But this doesnt work?
1.check your cartridge quility by coping an document 1a.if you have bad printing check expire date on cartridges if cartridges have not expire try cleaning cartridges from printers menu 1b.if you have a good printing from copy you need to reinstall printer in your pc using printers cd
Take it aparts,check the fuse,if it burn,or the felement across broken it dead.Change the fuse,same vale ok exsample like 1A must be 1A.After that don't work,then u have burn circuits boards prob.
