My Harman Kardon HK395 Satalite speakers have started to make crackling , static noise when hitting lower basey sounds , when watching film especially. Took back off sub woofer and found one capacitor thats suspect and component "104J 2A"?? Both have signs of leakage. Could these be the problem?
Hi Roovejet.
The capacitor 104 is 0.1uf ceramic has no reading with analogue multimeter in any range of ohms scale.
if it read any of ohms value ,it is bad.
please check the large electrolytic capacitors too and loose connection for the board and.if you have volume controllers clean it with alcohol or contact cleaners.
if your device is older than 5 years it is time to change all the electrolytic capacitors.its sound like foolish but it brings new life and same quality when your buying time to the sound system.
regards.
nuwan
SOURCE: my dell hk395 speakers making noise
view the following page:
http://support.dell.com/support/edocs/acc/hk395/en/trouble.htm
~gnomer
SOURCE: I need a new HK395
Try http://www.redplanettrading.com/search.php?mode=search&page=1. They have the HK395 model for a pretty good deal and they might be willing to cut you a deal for just the part.
