Asrock P4i65G Motherboard Logo
s
sandro gammaitoni Posted on Jan 17, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sata driver bios raid ahci
Can I install ahci drivers?
Lars Olsson
Level 3:
Brigadier General:
  • Asrock Master 3,400 Answers
  • Posted on Jan 18, 2014
Lars Olsson
Asrock Master
Level 3:
Brigadier General:
Answers
3400
Questions
Helped
1049180
Points
10330
PURCHESE A BETTER MOTHERBOARD INSTEAD.
  • sandro gammaitoni
    sandro gammaitoni Jan 18, 2014
    Yes, I shall "PURCHESE" it !!!!
4 Related Answers
Anonymous
  • 883 Answers
  • Posted on Aug 16, 2007
SOURCE: Can't install Hard Drive MS Server 2003
try running scandisk on the floppy disc to fix errors with the txtsetup.oem file.
Anonymous
  • Posted on Dec 19, 2008
SOURCE: Device Manager shows VIA SATA RAID Controller with Yellow "!"
same problem.....for help contact dragosdogaru1985 yahoo messenger
Anonymous
  • Posted on Mar 01, 2009
SOURCE: Does Asrock P4VM8 support 500GB SATA hard disks?
near the interface port of the hard drive you have to put a jumper that limit the connection speed from 3.0giga per second to 1.5giga per second, I think that would solve the problem because the hard drive speed goes to 3 giga per second and the motherboard p4vm8 serial ata port can support up to 1.5giga per second.
Anonymous
  • 2351 Answers
  • Posted on Apr 08, 2010
SOURCE: how to use sata raid
Open the links provided below to help setup an array; http://www.pcstats.com/articleview.cfm?articleID=830
And; http://www.pctechguide.com/tutorials/RAID.htm
Motherboards that support RAID will have a bios setting that will need to be enabled. The links above will help you setup an array.
Cheers'
Mike
1helpful
Asus motherboard problems Installed a new F2A55-MLK series to replace old ASUS board. Running XP and when I install the HDD it boots until the starting windows screen and get blue screen Asus tech no help.
go into the BIOS setup and find settings for SATA operation or something similar. the available options should be
1. Native SATA/IDE
2. AHCI supported
3. RAID
windows xp was installed with SATA support but requires special drivers for AHCI or RAID, so you should set your computer's SATA operation to native or IDE in order to solve the problem.
Additional tip:
next time you manage to boot to windows, boot to safe mode (boot while pressing F8), so you can review if all the drivers are well installed in device manager.
How to change sata to ata in bios
If you want to install Windows XP or configure a RAID array, you may need to change the SATA type in BIOS. here I will introduce some method of SATA settings in BIOS. SATA HDD(hard disk) has been more porpular because of the hight transferring speed and simple installation. If you want to Install a Windows XP in SATA hard disk. we offen need a floppy disk to save the additional driver of SATA/RAID. but the floppy isn't too easy to find. So we can do another method, modify the SATA type to compatible IDE or ATA mode, etc.
Notes: If your computer has installed some operating systems. Changing SATA types may corrupt your systems or need to be repaired again. But when can I change the SATA type?
1. You are prepairing install a new operating systems, for commonly Windows XP. If Windows 7/Vista will be installed. you need nothing changed in BIOS unless the setting has been modified.
2. Or you want to install a RAID.
I will introduce how to install Windows XP at SATA HDD(hard disk) in the coming chapters, here we need to know how to change the SATA type in BIOS. At first we need to access BIOS, Here is my desktop BIOS, we can find the BIOS is from AWARD software.
201003290718324672.jpgIn my BIOS, the harddisk settings are in the line of integrated peripherals, different BIOS or different OEM menufactures may have different promise. you can try the Advanced BIOS features setting or Integrated peripherals, or system configuration, etc.
Locale to Integrated Peripherals and press enter, you may find the SATA configuration.
201004010308121905.jpgthe above screenshot is the SATA configuration position. There are two items about SATA controller, Onchip SATA controller and Onchip SATA Type, Notes: There may be one or more configurations about SATA, we only need to change the SATA Type. you should not close the SATA controller if you don't know what's will be happened.
Navagete to the Onchip SATA Type and press ENTER, we can find these selections: Native IDE, AHCI, RAID. If you want to install Windows XP, you may need to change to Native IDE(some called ATA) mode, when you finished installation, you can refresh your SATA drivers in Windows XP and change the SATA type to AHCI mode in BIOS again.
If you want to configure a raid array. set to RAID similarity. When finished settings, you should press enter to accept it, and save to CMOS before restart your computer. In my BIOS, I need to exit to the BIOS main menu at first and save it.
when the new status has been saved, you can press CTRL+ALT+DEL to restart your computer, some OEM PCs may need to click the EXIT or Save to CMOS and Exit, the computer will be restart automatically.
Another example screenshot is my DELL notebook BIOS. DELL BIOS is not the same as the desktop BIOS, we can find the SATA operation behind the System Configuration. there are only three selections (Disabled, ATA, AHCI). If you want to install Windows XP, here need to be changed as ATA mode.
201004010308185104.jpg Notes: If you want to install operating systems, you may need to change the boot orderto boot from your CD/DVD drive.
Need manual for C51GU01
In the bios there's an option to configure SATA as "IDE", "AHCI", or "RAID".
If you don't have data to loose, try this. Install the drive, set the BIOS option to "IDE", boot to windows, install manufacturer's IDE/SATA controller drivers, restart, set the BIOS option to "AHCI".
AHCI stands for Advanced Host Controller Interface. There are rumors that setting AHCI without manufacturer's drivers will give you a BSOD. I'm not sure if you can recover it by switching back to "IDE", but it should be worth a shot.
Best of luck
1helpful
How do I unfreeze frozen sata port0
If the issue is that it does not see the hard disk on the 0 port ...and it gives you blue screen memory error ..it means it does not have the ahci driver installed ..you need to instal it as a 3rd party ...or ..go to bios settings (press f2 on start ) .select the hdd and under the settings for it ..disable the ahci for sata ..and select ide or ide compatible ..or sata as ide..depending on choices..
save settings with F10 and restart ..It will make the port functional ..
If you want to install with the advanced host controller interface ..than press f6 I think ...when it asks for 3rd party driver ..and try to load it from a usb device by browsing for it ..(in normal mode you need a floppy drive ) ..but it may work ..be sure the usb is enabled in bios..
if it does not work ..than make a boot-able usb memory ..with the operation system ..and use it and insert the driver disk in the dvd drive ..and will work ..This way .when it asks for 3rd party drivers..you will load the raid driver and the ahci driver ..and go on with the installing ..
1helpful
Mother board masi km4am-l H.D.D. 1 TRA WES 64MB when installing win xp hard not detected by win setup. I updated bios but not worked. advance thanks
you should not update the bios...the issue is the hard disk is on sata ...and you need a raid driver installed to detect the hdd...so ...either get into BIOS and under advanced features..look the place where the drives are detected..and select the hdd and look for a feature called AHCI ..and disable it ..and leave sata like ide..and save with f10 and restart ...after that the hdd will be seen ..
another way is to make a floppy disk with the raid driver on it (the one from the mothermoard drivers disk ) ..and when it ask you to press f6 for 3rd party software ...press it ..and insert the floppy ...it will pick up the raid driver and will go like a charm ..
if you do not have a floppy ..install a second cd drive ..and use a cd ..and after pressing f6 for 3rd party ..browse and point to the raid driver on the mobo driver cd ..
I want to install xp2 in compaq presario cq40, but a blue screen is show
Hello Download the SATA driver for your particular chipset. Then download nlite (just google it). Install it and follow the directions to slipstream the driver into your installation disc. You can also add SP3 and all the drivers you need to it.
or go to bios and restore it to default setting if you have a sata hard disk then disable it in bios setting or RAID Auto/Ahci to RAID Auto/ATA then reboot from installation disk or You can get help from this site http://www.laptops-drivers.com/compaq/how-to-install-windows-xp-on-hp-compaq-cq40-115au.html
hope this helps
After installing another HDD from another Packard Bell computer, the computer would not boot. This computer I recieved from a mate and I dont believe windows was removed, as I have tryed and failed...
if it is a sata Hdd you have to reinstall it ..cause the sata driver on the os ..is from the other computer ..or go to bios ..and in the drives feature..look for a function called AHCI and disable it ...
after that will boot with the windows installed..but you will have to reinstall the windows anyway ..and if it is a raid sata you need to insert a diskette with the sata driver during ..or disable the ahci function ..for to let it see the HDD ..if not all it will say is that the hdd was not found..or if you try to boot with this windows on it .will say that the media is missing ..
beter to set the defaults in the bios ..and after that look for that funstion to be disabled..or disable the raid sata ..and enable teh sata Ide..instead..it is the same thing ..and will pick up the sata hdd with no sweat ..
2helpful
Trying to install vista 32 bit on my Gateway DX 4720-03.Vista won't install because it can't see Hard drive. How do i disable ahci or sata mode in the bios or is there a work around to install Vista32.
Vista will have the drivers necessary to identify SATA/AHCI controllers, built-in by default. It would not be necessary to turn the AHCI mode 'off' or to 'ATA' mode (unless you get a 7B or inaccessible boot device BSOD). Check if your system has a RAID configuration, in which case there may be a 3rd party supplied RAID driver that you need to install first. Also, check if the HDD cables are connected properly & the HDD is detected in the BIOS (System setup screen) first.
Top Asrock Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
