20 Most Recent Asrock 775i65G Motherboard Questions & Answers
Asrock 775i65G fsb 1066 fsb motherboard , mobo. clocking problems.
there are 3 versions of that card, G1, g2 and G3, hardware generation. (G models ,not GV) Guess G3 version: xp 32 bit or 64b it is max OS for eternity, the virus magnet. I read G3 manual for you.. easy. RTM did you read, ddr caution 1 to 5 first. on DDR? and CPU, both. both matters. my guess is you failed to read PAGE, fully or not at all. read it. not told using, AGP video card, listed on QVL? not told is AGP cocking tied or untied in bios page. same if you overclock the memory the AGP card fails, if tied. so rule #1 do not do that. are you mucking with overclock settings, why not just set clock to DDR spec speed max and CPU speed max which ever is less. Supports DDR400/333/266, 2 sticks max. Quote caution 1 "FSB1066-CPU is supported only when you install AGP VGA card into AGP slot. Besides, if you use a FSB1066-CPU on this motherboard, please adopt a DDR400 CL2.5 memory module." 2GB max" BIOS page, turn on memory timing by SPD (plug and play chip on sticks) The bios will not know what CPU max is and then read he SPD chip and if equal it runs at that speed, or IF ether is lower spec. the speed is at the lower, do not overclock chips as that causes overheating and hard failures. but is you cash lost not mine and down time. and even BSODs endless. (kids being kids) the manuals on old mobo are clear on this and how. no ram models told (sku models) nor how many or size ddr and if a matched pair is it MUST BE, (intel told you to !) no CpU told, full model # of CPU not told. is this CPU 1066? rated , NOT TOLD. so any easy answers wow hard. learn to post using notepad MYbuild.txt FILE. make a file and type all details of the this custom build. then post that first so we can end guessing all that. and get exact answers. if GPU used, tell maker and model about 1/2 of all made fail. so... cpu exact model not old (the lid of CPU all words there MATTER) ddr size pair models.# (labels have P/n#) set all ddr to auto. and do not overclock use tied mode. (this scales fsb to gpu speed so can not fail) Untied is overclocking mode, avoid that. (is dual clock settings) learn to do this the safe way then later overclock (why) and break it later and then at that moment you know you did that, say next week? and damage does happen.. doing that, costly too,., fsb-undefined-undefined-0.jpg enable the SPD, this line means SPD ( is the sticks Plug and Play WHO AM I CHIP) it in facts contains the full spec of the DDR inside SPD) this act (SPD enabled) sets the CPU to the speed max the paired DDR, to max allowed allowed (which ever is the lesser wins) nothing works better and for longer. even a hot PC,
5/7/2022 3:28:02 PM • Asrock 775i65G... • Answered on May 07, 2022
2answers
775i65g Drivers for windows 7? please help
windows 7 will use the xp or vista drivers.
you may need to install it manually
1.) click start
2.) right click computer
3.) click properties
4.) click device manager
5.) make sure your driver cd is in the cd drive
6.) right click any device with a yellow marker and select update driver
7.) follow the on screeb instructions for windows 7 to browse and install the drivers for you.
If you have an internet connection run windows update
the drivers will be in the updates.
if you have to download the drivers then u will need to unzip it to a folder and specifiy that folder when you choose to update your device. (6.7 above)
drivers can be downloaded from the manufactures web site for your device.
11/27/2017 12:20:58 AM • Asrock 775i65G... • Answered on Nov 27, 2017
Driveraudio
Here you go... ASRock 775i65G
7/9/2016 6:13:50 PM • Asrock 775i65G... • Answered on Jul 09, 2016
WANT AUDIO DRIVER FOR INTEL D4B and D4A
Intel homepage.
4/22/2016 12:19:04 AM • Asrock 775i65G... • Answered on Apr 22, 2016
Problem with upgrading ram on Asrock 775i65G Motherboard
Hello download the manual here:http://www.asrock.com/mb/Intel/775i65G/?cat=Manual It explains the problem.You will need adobe reader, to read content.Good luck
6/29/2015 7:18:23 AM • Asrock 775i65G... • Answered on Jun 29, 2015
Asrock motherboard 775i65g beep codes
check your RAM
8/10/2014 11:02:18 AM • Asrock 775i65G... • Answered on Aug 10, 2014
Why CMOS settings are wrong every time
check cmos battery out change it out
5/25/2014 3:18:43 AM • Asrock 775i65G... • Answered on May 25, 2014
Do not show display ib775i65h mother bord
are the drivers in if so then video card
5/25/2014 1:50:34 AM • Asrock 775i65G... • Answered on May 25, 2014
P4 model model 775i65gv audio
You can go to the manafacturs web site and down load all the drivers you need
4/19/2014 6:57:28 PM • Asrock 775i65G... • Answered on Apr 19, 2014
Bios recover
CLEAR CMOS,IT WILL RESET BIOS ORGINAL SETTINGS.
12/29/2013 10:09:42 AM • Asrock 775i65G... • Answered on Dec 29, 2013
0answers
Sound driver
Be the first to answer 12/15/2013 1:24:05 PM • Asrock 775i65G... • Posted on Dec 15, 2013Be the first to answer
0answers
0answers
0answers
Bios p3 00
Be the first to answer 10/12/2013 10:42:02 AM • Asrock 775i65G... • Posted on Oct 12, 2013Be the first to answer
0answers
2answers
What happens if transistor d452 faulty?
SHORT D452 ON MOTHER BOARD WHAT OTHER TRANSISTER CAN USE
7/10/2013 6:52:58 AM • Asrock 775i65G... • Answered on Jul 10, 2013
Asrock 775i65G Motherboard Logo
155 questions posted
Top Asrock Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Asrock Computers & Internet
Most Popular Question
download vga driver asrock 775i65g
  • Computers & Internet
