How can simply remove the reservoir
SOURCE: windshield washer fluid reservoir - MB ML 350
right where the lines connect to reservoir, has little black seals that leak. I recommend removing reservoir, empty it out, then use RTV silicone and place it between seals and reservoir. Let it dry for FULL day. than reinstall.
SOURCE: water leaking from windscreen washers cant find
hey cheap ***** , if you could afford a mercedes you can afford to bring it to the dealer cheap ***
SOURCE: I have been told that
Hummm, interesting. Perhaps there is some conductivity property to the MB fluid. To test, drain out all of the fulid and install MB fluid and you will have your answer.
