Shower leak is it possible from Moen diverter to shower head
Only happens when shower on and for short ime afterwards can hear drip. can ear steady drip sound, and amount of water seems too light for it to be drain. leaking through ceiling below stall shower
Re: shower leak is it possible from Moen diverter to...
Check around the the front of shower and make sure there is no place that water can seep thru such as old calk and or loose tile and around fixture molding
You will have to replace the shower diverter button. Remove the handle, remove the faceplate, and the diverter will screw out. Any plumbing supply that carries Moen products will have a replacement button for your valve
a lot of shower diverters do this..you may need a bigger seal on the diverter..if you can remove the spout assembly from the tub(with the diverter valve in it) and take it all to the hardware store.. see if they have a different seal/diverter that has a snugger fit but still falls to drain the shower head line out..that will slow that leakage..the spout is on a pipe and unscrews counter clockwise(normally)unless its a single valve unit..with the wide ring around the back..then that calls for a plumber..
Not unless you had a backward plumber , If the diverter at the faucet is open for tub, then no water will go up the shower, The shower may hold enough water up there to make it look like a drip, Even if the valve was leaking all the time, it would not go up, it would come out the faucet. It only works with pressure. Unless the valve was plumbed wrong,,, Hope this helps.
