Microsoft Office Access 2003 (077-02871) for PC Logo
Posted on May 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Access 2003 wont start
I have just had to reformat my hard drive and have loaded Microsoft Office professional 2003 - all the programs are running except the one I really need - Access. When I try to load it (from the programs, all, office task bar- it says reconfiguring Office 2003 and nothing happens!! All the other programs open as normal.I have tried uninstalling, reinstalling, the software fix on the disk but still no joy. I am at frustration level 10 - any ideas??
Anonymous
Level 2:
Scholar:
  • Expert 89 Answers
  • Posted on May 27, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
89
Questions
0
Helped
44766
Points
261
Try to go into the run command and type access then hit enter, see if it loads from there, you can also do this from task manager > New Task and type access. see if it runs then. If not let me know
I had publisher loaded on my computer. It would have been 2003. The computer crashed and I am now unable to use this programme. The icon is still on the desktop and is in My Documents, however when I...
if you have the program on a disc you could uninstall it then turn off your computer then reinstall it
or
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
hope this helps
My dsughters school sent me something and I can't open it becouse I need Microsoft Office 2003 Product Key Number.
Search online for the PRODUKEY software.
Download it, install it, and run it.
If Microsoft Office 2003 is installed on your computer, then PRODUKEY will tell you what license-key was used when Office was installed.
Or, access http://office.microsoft.com and search for "Word Viewer" or "Excel Viewer" or "PowerPoint Viewer", and download and install these programs.
These programs are FREE software to allow you to "view", but not "change', documents created by all versions of Microsoft Office.
2answers
Excel versus professional edition 2003
Hi Richard,
take a step back, and notice that they are talking about Microsoft Office Professional 2003, and not Windows XP Professional.
If you try to open an office document, in your case a .XLS file, and it says You need to insert the setup disk, then the install of Office is corrupt, and/or there are missing files that Office cannot locate.
you could cross your fingers and see if you perform a repair on Office.
you do this from Control Panel > Add Remove Programs, Click on MS Office 2003 Professional, and click Change/Remove . when the wizard starts, click Next and choose Repair .
it may still ask for the setup disks, or to browse to the folder where the setup cache files are located.
if this is the case, and you don't have the disk, your only option is to track down someone else who has the disk, or the folder on their c:\ where office offers to save its install files for the future when it might be needed.
I suspect that you did a File Cleanup on your c:\ and either you accidentally deleted the c:\MSOCache folder (which is hidden), or the Clean Up Wizard deleted it for you.
if you know someone with a PC with office 2003, you can copy this hidden file to your flash drive, and then dump the files back onto your computer.
i hope this helps.
____________________
Alternatively, you can use Open Office, a free download , fully fledged office suite of applications. not made by microsoft, but similar enough to perform the same tasks without much hassle or relearning.
Unable to fix or remove microsoft office 2003
If you cloned the hard drive, everything should work. In windows, that's what you need to do if you don't have a utility to actually move your programs to a new hard drive.
The answer to your problem is: Reinstall the program from the program CD.
3answers
The microsoft office 2003 installation
First do this
To resolve this behavior, start the Setup program for Office. To do this, follow these steps:
  1. Insert the Microsoft Office 2003 CD in your CD drive or DVD drive.
  2. If the Setup program does not start automatically, locate the Setup.exe file on the CD, and then double-click the file to start Setup.
  3. After the Setup window appears, cancel Setup, and then respond to the prompts to exit Setup.
Note You do not have to complete the Setup program. Setup fixes the error condition when it is first invoked.
If it doesn't help follow these steps.
go to add/remove programs via control panel
the go to office 2003
select "change".
Select repair
You will be asked for the installation CD. Please insert it before start this procedure.
Then do a repair and follow the instructions
Thanks
If this helps you, please rat the answer
Good Luck
Ms word wont run . when i click the ms word menu it will not run, and always ask me to run in safe mode. no matter how i re-install the program, still it will ask to run in safe mode
Delete this follwing key
Start > Run > Regedit
HKEY_CURRENT_USER\Software\Microsoft\Office\12.0\Word\Data
HKEY_CURRENT_USER\Software\Microsoft\Office\Word\Addins
Does anyone have clue about the " Pro.Msi" File
An .msi file is a database of all the files, settings, and configuration information for the associated application. When you install Office on your computer, the .msi file is saved in a hidden folder. Without this file, Windows Installer cannot update your configuration, install optional features, or apply software updates. Office cannot be installed, repaired, or updated if the .msi file is not found.
Why is the .msi file missing? The most likely reason for Windows Installer to require the installation CD is because the saved version of the .msi file for Office has been inadvertently or deliberately deleted from your computer. It is also possible that the file is damaged or corrupted.
Occasionally, changing the drive letters associated with partitions on your hard disk can cause this problem to occur — such as changing drive C: to a different letter or moving the hard disk drive from one computer to another. Other possible causes are a damaged or corrupted hard disk or registry file.
What to do when prompted for a missing .msi file If you are prompted for the location of a missing .msi file, you must provide the original installation CD used to install Office on your computer.
  1. Make sure that you have inserted your Office installation CD into the CD drive of your computer. If you installed Office from a network, browse to the network location from which you installed Office.
  2. Click Retry.
In most cases, these steps should resolve the problem and Office can complete the installation and configuration of the needed component.
default.aspx?assetid=za790050011033I don't have the installation CD
Without the installation CD — or for computers purchased from companies such as Dell, HP, Compaq, or Gateway — you need to provide a repair CD to reset the installation created for your computer by the manufacturer. For information on how to apply the repair or installation CDs, you might need to contact the support representatives of your computer supplier.
In many cases, the files that you need are compressed on the repair CD and must be run by using a special program provided by the computer manufacturer. In some cases, the computer manufacturers might have customized the .msi file or changed the file name.
In situations where you cannot obtain the installation CD, your options are the following:
  • Continue with the existing installation of Office without updating. This is not recommended. Your documents and computer might become compromised from security threats.
  • Remove the installation and reinstall Office by using another installation CD. Removing the previous installation may not be possible in severely damaged systems where the registry is corrupt.
  • Run a repair CD provided by the computer manufacturer. For information on how to apply the repair CD, you might have to contact the computer manufacturer or consult the documentation provided with the computer.
If you do not know which version of Office you have installed, the name of the .msi file requested indicates the Office version you have. A table that correlates .msi files to Office versions is provided later in this article.
Office 2003, Office XP, and Office 2000 provide the Detect and Repair command. You can find the Detect and Repair command on the Help menu of almost all Office programs. Using this command corrects identifiable problems such as missing files, corrupt files, registry omissions, or damaged registry entries. It replaces the .msi file if it was deleted, damaged, or is the wrong version. Using the Detect and Repair command usually requires you to provide the installation CD for the version of Office currently installed on your computer.
default.aspx?assetid=za011526611033 How to prevent similar problems in the future To help avoid this problem in the future, use the following guidelines:
  • Do not delete hidden folders or files from any drives on your computer.
  • Do not move drives or change their disk identifier (for example, C: to D:).
  • Install all needed applications as Run from My Computer instead of using Install on Demand (available from custom installation within Setup).
  • Occasionally run the Windows Disk Defragment program to repair cross-linked files, recover lost clusters, and remap bad sectors on your hard disk. Any data present in a bad portion of the hard disk is usually lost and commonly associated with physical damage to the disk. This is most likely the result of high-vibration environments, such as the computer being struck, dropped, or kicked.
If you have Microsoft Windows XP as your operating system, consider using the System Restore option to restore your system to a previous configuration. Consult the Help and Support option of Windows XP for more information on System Restore.
Office 2003 .msi files If you do not know which version of Office you have installed, the name of the .msi file requested indicates the Office version you have. The following tables tell which .msi files go with which Office versions.
File name Description accessed.msi Microsoft Office Access 2003 Developer Extensions mui.msi Microsoft Office 2003 Multilingual User Interface Pack (one for each language) muiwiz.msi Microsoft Office 2003 Multilingual User Interface Pack owc11.msi Microsoft Office 2003 Web Components prjmuicwz.msi Microsoft Office Project 2003 Multilingual User Interface Pack Wizard prjstde.msi Microsoft Office Project Standard 2003 pro11.msi Microsoft Office Professional Edition 2003 projproe.msi Microsoft Office Project Professional 2003 ptk.msi Microsoft Office 2003 Proofing Tools sbe11.msi Microsoft Office Small Business Edition 2003 vismuiwz.msi Microsoft Office Visio 2003 Multilingual User Interface Pack Wizard visprolmxi.msi Microsoft Office Visio Professional 2003 Office XP .msi files File name Description dao.msi Microsoft Data Access Object (DAO) lpk.msi Microsoft Office XP User Interface Pack (one for each language) lpkwiz.msi Microsoft Office XP User Interface Pack Wizard ork.msi Microsoft Office XP Resource Kit pro.msi Microsoft Office XP Professional Edition proplus.msi Microsoft Office XP Professional with FrontPage Edition ptk.msi Microsoft Office XP Proofing Tool Kit pub.msi Microsoft Publisher 2002 sbe.msi Microsoft Office XP Small Business Edition std.msi Microsoft Office XP Standard stdedut.msi Microsoft Office XP Standard for Students and Teachers owc10.msi Microsoft Office XP Web Components Office 2000 .msi files File name Description data1.msi Microsoft Office 2000 Premium Edition (all Office products) data1.msi Microsoft Office 2000 Professional Edition (similar to Premium but does not include Microsoft PhotoDraw) data1.msi Microsoft Office 2000 Small Business Edition (includes Microsoft Word, Microsoft Excel, and Microsoft Outlook) data1.msi Microsoft Office 2000 Standard Edition (includes Microsoft PowerPoint, Word, Excel, and Outlook) data2.msi Microsoft Office 2000 Disc 2 (includes Small Business Tools and Publisher) msowc.msi Microsoft Office 2000 Web Components orkdata.msi Microsoft Office 2000 Resource Kit proofkit.msi Microsoft Office 2000 Proofing Toolkit Note In Office 2000, the file name data1.msi does not clearly identify which version of Office you have. In this case, you need to inventory the installation of Office programs on your computer by examining your Start menu entries or click Add or Remove Programs in Control Panel and scan through the list of entries to determine the version of Office that is installed.
Zulfikat Ali
Mixing MS Office 2003 with MS Access 2007
hi there
you can upgrade to access 2007 from office 2003, however if you do that you will end up losing the other office programs such as outlook, word, powerpoint etc..
hope this helps
http://office.microsoft.com/en-us/products/FX101754511033.aspx
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
